Gigabyte GeForce GTX 1070 G1 GAMING 8GB GDDR5 Windforce3X
Quicklinx: C5QNWS00 Mfr#: GV-N1070G1 GAMING-8GD
Gigabyte GeForce GTX 1070 G1 Gaming
Features:
Power by GeForce® GTX 1070
Integrated with 8GB GDDR5 256bit memory
WINDFORCE 3X with Blade Fan Design
Support up to 8K display @60Hz (requires 2*DP1.3 connectors)
16.8M Customizable Color RGB Lighting
Core:
Boost: 1822 MHz/ Base: 1620 MHz in OC Mode
Boost: 1784 MHz/ Base: 1594 MHz in Gaming Mode
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX. GeForce GTX delivers the fastest performance, with the most advance gaming technologies (NVIDIA GameWorks™) and the best gaming ecosystem (GeForce Experience™).
Cinematic Game Experience
GameWorks™ pushes the limits of gaming by providing a more interactive and cinematic game experience and thus enabling next gen gaming for current games.
Tear-free Gameplay
G-SYNC’s revolutionary smoothness is achieved by synchronizing display refresh rates to the GPU in your GeForce GTX-powered desktop or notebook, eliminating screen tearing and minimizing display stutter and input lag.
Amazing Virtual Reality Experience
Get you ready for the fast performance and low latency required for an amazing virtual reality experience.
G1 GAMING
GIGABYTE G1 Gaming Series graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary NVIDIA® Pascal™ GPU architecture, G1 gaming graphics card brings you incredible gaming experience.
- Pascal-powered graphics card give you superior performance and power efficiency
- Support up to 8K display @60Hz
- Outstanding performance for Virtual Reality gaming
WINDFORCE 3X
The WINDFORCE 3X cooling system features 2 pure copper composite heat-pipes, special fin architecture, unique blade fan design, together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
The airflow is spilt by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. The LED fan indicator on the top of the graphics card provides an instant display of the fan status.
The composite heat-pipes combines both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases 29% of cooling capacity.
The pure copper heat pipes are shaped to maximize the direct contact area to the GPU.
16.8M Customizable Color Lighting
With 16.8M customizable color options and numerous lighting effects, you could now choose the right scheme for your gaming rig through XTREME Engine utility.
One-click Super overclocking
With a simple click on XTREME Engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment.
GPU Gauntlet™ Sorting
Forged with only the top-notch GPU, the Gigabyte G1 GAMING graphics cards guarantee higher overclocking capability in terms of excellent power switching, ensuring the highest performance without compromising system reliability.
Smart Power LED indicators
Be alert when PCI-E voltage is unstable with the smart power LED indicator.
Built for OverClocking with 6+2 power phases
Compared to founders edition, the 6+2 power phases on the card make the MOSFET working at a lower temperature and provide more stable voltage output.
Xtreme Engine
Adjust clock speeds, voltage, fan performance, RGB lighting effect, power target, OSD setting can be monitored and tuned in real-time according to your own preference through this intuitive interface.
  • The ultimate PC gaming platform
    Get Game Ready with GeForce GTX. GeForce GTX delivers the fastest performance, with the most advance gaming technologies (NVIDIA GameWorks) and the best gaming ecosystem (GeForce Experience).
  • Cinematic game experience
    GameWorks pushes the limits of gaming by providing a more interactive and cinematic game experience and thus enabling next gen gaming for current games.
  • Tear-free gameplay
    G-SYNC's revolutionary smoothness is achieved by synchronizing display refresh rates to the GPU in your GeForce GTX-powered desktop or notebook, eliminating screen tearing and minimizing display stutter and input lag.
  • Amazing virtual reality experience
  • The WINDFORCE 3X cooling system
  • Unique blade fan design
    The airflow is split by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
  • 3D active fan with LED indicators
  • Composite heat-pipes
  • Heat pipe direct touch
  • 16.8M customizable color lighting
Gigabyte GeForce GTX 1070 G1 Gaming - OC Edition - graphics card - GF GTX 1070 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1070
8 GB GDDR5
Core Clock
1620 MHz
Boost Clock
1822 MHz
Effective Memory Clock
8.008 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
4.2 cm x 28.6 cm x 11.5 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1620 MHz
Boost Clock
1822 MHz
Process Technology
16 nm
VR Ready
Max Resolution
7680 x 4320 at 60 Hz
4
Interfaces Details
API Supported
GIGABYTE GPU Gauntlet Sorting, GIGABYTE WindForce 3x, NVIDIA G-Sync ready, Heat Pipe Direct Touch technology, Nvidia GeForce GTX VR Ready
Size
8 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
4.2 cm
28.6 cm
11.5 cm
