Crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Base on the revolutionary NVIDIA Pascal GPU architecture and cleverly designed for VR. It boasts high-specs and a variety of technologies to push your gaming limits to the max. There are various aspects to the cooling system embedded into the 1060 Xtreme Gaming GPU, that come together to create an impressive and effective heat dissipation system. This 1060 cooling features GIGABYTE patent-pending 3x 100mm stacked fans, unique blade fan design, double ball bearing structure, angular fin design and 6 composite heat-pipes with direct touch on the GPU. Experience higher performance at lower temperatures with the XTREME GTX 1060.
Clever layering of this 1060's fans has allowed for larger fans (100mm) to be installed, providing a larger and more smooth airflow. Compared to the standard 3x 80mm fans , the WINDFORCE stack fans create 10% enhanced cooling performance.
- Gigabyte GeForce GTX 1060 Xtreme Gaming 6G - OC Edition - graphics card - GF GTX 1060 - 6 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1060
- Memory
- 6 GB GDDR5
- Core Clock
- 1645 MHz
- Boost Clock
- 1873 MHz
- Effective Memory Clock
- 8.316 GHz
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 5.7 cm x 28 cm x 13.2 cm
- 4 years warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1645 MHz
- Boost Clock
- 1873 MHz
- Process Technology
- 16 nm
- VR Ready
- Max Resolution
- 7680 x 4320 at 60 Hz
- 4
- API Supported
- Ultra Durable VGA, LED indicator, heatpipe cooling, GIGABYTE WindForce 2x, 6+1 Phase Power System, NVIDIA G-Sync ready, NVIDIA GameWorks, Nvidia GeForce GTX VR Ready
- Size
- 6 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.316 GHz
- Bus Width
- 192-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 8 pin PCI Express power connector
- Included Accessories
- Backplate
- Software Included
- XTREME Engine Utility
- 5.7 cm
- 28 cm
- 13.2 cm
- Limited warranty - 4 Years
