Gigabyte GeForce GTX 1060 Windforce OC 6GB GDDR5 PCIe Graphics Card
Quicklinx: CCPWWS00 Mfr#: GV-N1060WF2OC-6GD
WINDFORCE 2X Cooling System
The WINDFORCE 2X cooling system features two 90mm unique blade fans, alternate spinning fan design, pure copper composite heat-pipe, heat pipe direct touch technology, semi-passive 3D active fan, and protection back plate together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
WINDFORCE 2X Cooling System- Fans
Alternate Spinning Fan Design
Optimize air flow by the alternate spinning fans that reduce air turbulence and effectively dissipate the heat.
90mm Unique Blade Fan Design
The airflow is spilt by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
3D Active Fan
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle.
WINDFORCE 2X Cooling System- Heat Pipe
Composite heat-pipe
The composite heat-pipe combines both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases 29% of cooling capacity.
Heat Pipe Direct Touch
The pure copper heat pipe is shaped to maximize the direct contact area to the GPU.
WINDFORCE Cooling System- protection back plate Protection back plate
Glorious black back plate provides the solid protection, strengthens the structure and inspires the passion for gaming.
Performance
One-click Super overclocking
With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment.
Durability
Ultra Durable Components
Engineered with the highest-grade chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan.
Built for OverClocking with 4+1 power phases
Compared to founders edition, the 4+1 power phases on the card make the MOSFET working at a lower temperature and provide more stable voltage output. (*founders edition:3+1)
Intuitive Utility
Intuitive XTREME Engine Utility
Adjust clock speeds, voltage, fan performance, power target, OSD setting can be monitored and tuned in real-time according to your own preference through this intuitive interface.
  • WINDFORCE 2X cooling system
    The WINDFORCE 2X cooling system features two 90 mm unique blade fans, alternate spinning fan design, pure copper composite heat-pipe, heat pipe direct touch technology, semi-passive 3D active fan, and protection back plate together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
  • Alternate spinning fan design
  • 90 mm unique blade fan design
    The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
  • 3D active fan
  • Composite heat-pipe
  • Heat pipe direct touch
  • Protection back plate
Gigabyte GeForce GTX 1060 WINDFORCE OC 6G - graphics card - GF GTX 1060 - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
6 GB GDDR5
Core Clock
1582 MHz
Boost Clock
1797 MHz
Effective Memory Clock
8.008 GHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Resolution Details
DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported
4
Interfaces Details
2 x DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.9 cm x 22.3 cm x 12.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1582 MHz
Boost Clock
1797 MHz
Process Technology
16 nm
VR Ready
Max Resolution
4
Interfaces Details
API Supported
Ultra Durable VGA, GIGABYTE WindForce 2x, NVIDIA G-Sync ready, NVIDIA GameWorks, Heat Pipe Direct Touch technology, Nvidia GeForce GTX VR Ready, 4+1 Phase Power Design, 90mm Unique blade fan design
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
192-bit
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
Backplate
Software Included
GeForce Experience
3.9 cm
22.3 cm
12.1 cm
