Equipped with 2 pure copper heat pipes and unique-blade fan with 3D active functionality, and heat pipes direct touch technology, the cooler can dissipate heat effectively from the GPU while keeping the fan at lower speed and noise.
Unique blade fan design
The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow. -
3D active fan
The semi-passive fans will remain off, when the GPU is under a set loading or temperature for low-power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle. -
Composite heat pipes
The composite heat pipes combine both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases cooling capacity. -
Heat pipe direct touch
The pure copper heat pipes are shaped to maximize the direct contact area to the GPU. -
Ultra-durable graphic components
Engineered with the high-grade chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan.
- Gigabyte GeForce GTX 1060 Mini ITX OC 6G - OC Edition - graphics card - GF GTX 1060 - 6 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1060
- Memory
- 6 GB GDDR5
- Core Clock
- 1556 MHz
- Boost Clock
- 1771 MHz
- Effective Memory Clock
- 8.008 GHz
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x DVI-D (dual link) , DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 3.7 cm x 16.9 cm x 13.1 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1556 MHz
- Boost Clock
- 1771 MHz
- Process Technology
- 16 nm
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- Ultra Durable VGA, NVIDIA G-Sync ready, NVIDIA GameWorks, GIGABYTE custom-designed 90 mm cooler, Heat Pipe Direct Touch technology, Nvidia GeForce GTX VR Ready
- Size
- 6 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.008 GHz
- Bus Width
- 192-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 6 pin PCI Express power connector
- Software Included
- XTREME Engine Utility
- 3.7 cm
- 16.9 cm
- 13.1 cm
