GeForce® GTX 1060 G1 Gaming 6G
Powered by GeForce® GTX 1060
Integrated with 6GB GDDR5 192bit memory
WINDFORCE 2X with Blade Fan Design
Support up to 8K display @60Hz
16.8M Customizable Color RGB Lighting
Core Clock
Boost: 1847 MHz/ Base: 1620 MHz in OC Mode
Boost: 1809 MHz/ Base: 1594 MHz in Gaming
GIGABYTE G1 Gaming Series graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary NVIDIA® Pascal™ GPU architecture, G1 gaming graphics card brings you incredible gaming experience.
- Pascal-powered graphics card give you superior performance and power efficiency
- Support up to 8K display @60Hz
- Outstanding performance for Virtual Reality gaming
WINDFORCE
The WINDFORCE 2X cooling system features two 90mm unique blade fans, 2 pure copper composite heat-pipes, alternate spinning fan design, and heat pipes direct touch technology, together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
Alternate Spinning Fan Design
Optimize air flow by the alternate spinning fans that reduce air turbulence and effectively dissipate the heat.
Unique Blade Fan Design
The airflow is spilt by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
16.8M Customizable Color Lighting
With 16.8M customizable color options and numerous lighting effects, you could now choose the right scheme for your gaming rig through XTREME Engine utility.
One-click Super overclocking
With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment.
Intuitive XTREME Engine Utility
Adjust clock speeds, voltage, fan performance, RGB lighting effect, power target, OSD setting can be monitored and tuned in real-time according to your own preference through this intuitive interface.
The WINDFORCE 2X cooling system features two 90 mm unique blade fans, 2 pure copper composite heat-pipes, alternate spinning fan design, and heat pipes direct touch technology, together delivering an effective heat dissipation capacity for higher performance at lower temperatures. -
Alternate spinning fan design
Optimize air flow by the alternate spinning fans that reduce air turbulence and effectively dissipate the heat. -
Unique blade fan design
The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow. -
3D active fan with LED indicators
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. The LED fan indicator on the top of the graphics card provides an instant display of the fan status. -
Composite heat-pipes
The composite heat-pipes combines both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases cooling capacity. -
Heat pipe direct touch
The pure copper heat pipes are shaped to maximize the direct contact area to the GPU. -
16.8M customizable color lighting
With 16.8M customizable color variations and numerous lighting effects, you could now choose the right scheme for your gaming rig through XTREME Engine utility. -
Stylish metal back plate
The metal back plate offers rigidity and protection to the structure, while adding a sleek, clean look to the product. -
One-click super overclocking
With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment. -
GPU gauntlet sorting
Forged with only the advanced GPU, the Gigabyte G1 GAMING graphics cards guarantee higher overclocking capability in terms of excellent power switching, ensuring the highest performance without compromising system reliability. -
Smart power LED indicators
Be alert when PCI-E voltage is unstable with the smart power LED indicator. -
Ultra durable materials
Engineered with the high-grade chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan. -
Built for OverClocking with 6+1 power phases
Compared to reference design, the 6+1 power phases on the card make the MOSFET working at a lower temperature and provide more stable voltage output.
- Gigabyte GeForce GTX 1060 G1 Gaming 6G (rev. 1.0) - OC Edition - graphics card - GF GTX 1060 - 6 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1060
- Memory
- 6 GB GDDR5
- Core Clock
- 1620 MHz
- Boost Clock
- 1847 MHz
- Effective Memory Clock
- 8.008 GHz
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 4 cm x 27.8 cm x 11.4 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1620 MHz
- Boost Clock
- 1847 MHz
- Process Technology
- 16 nm
- VR Ready
- Max Resolution
- 7680 x 4320 at 60 Hz
- 4
- API Supported
- Ultra Durable VGA, LED indicator, GIGABYTE GPU Gauntlet Sorting, GIGABYTE WindForce 2x, 6+1 Phase Power System, NVIDIA G-Sync ready, NVIDIA GameWorks, Heat Pipe Direct Touch technology, Nvidia GeForce GTX VR Ready
- Size
- 6 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.008 GHz
- Bus Width
- 192-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 8 pin PCI Express power connector
- Software Included
- XTREME Engine Utility
- 4 cm
- 27.8 cm
- 11.4 cm
