GEFORCE GTX 1050
ESSENTIAL GEAR FOR EVERY GAMER
Everyone deserves great gaming. That’s why we created the fast, powerful GeForce® GTX 1050. Now, you can turn your PC into a true gaming rig, powered by NVIDIA Pascal™—the most advanced GPU architecture ever created. It’s loaded with innovative NVIDIA Game Ready technologies that let every gamer experience the latest titles in their full glory. #GameReady.
- Gigabyte GeForce GTX 1050 Ti Windforce OC 4G - graphics card - GF GTX 1050 Ti - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1050 Ti
- Memory
- 4 GB GDDR5
- Core Clock
- 1354 MHz
- Boost Clock
- 1468 MHz
- Effective Memory Clock
- 7.008 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 7680 x 4320
- Max Resolution Details
- DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , DisplayPort , 3 x HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 4 cm x 22.9 cm x 11.8 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1354 MHz
- Boost Clock
- 1468 MHz
- Process Technology
- 16 nm
- Max Resolution
- 7680 x 4320 at 60 Hz
- 4
- API Supported
- Ultra Durable VGA, GIGABYTE WindForce 2x, NVIDIA G-Sync ready, NVIDIA GameWorks, Heat Pipe Direct Touch technology, 4+1 Phase Power Design, 90mm Unique blade fan design
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.008 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 300 W
- Additional Requirements
- 6 pin PCI Express power connector
- Included Accessories
- Backplate
- Software Included
- GeForce Experience, XTREME Engine Utility
- 4 cm
- 22.9 cm
- 11.8 cm
