GEFORCE GTX 1050
ESSENTIAL GEAR FOR EVERY GAMER
Everyone deserves great gaming. That’s why we created the fast, powerful GeForce® GTX 1050. Now, you can turn your PC into a true gaming rig, powered by NVIDIA Pascal™—the most advanced GPU architecture ever created. It’s loaded with innovative NVIDIA Game Ready technologies that let every gamer experience the latest titles in their full glory. #GameReady.
Powered by GeForce® GTX 1050 Ti
Integrated with 4GB GDDR5 128bit memory
WINDFORCE 2X with Blade Fan Design
Support up to 8K display @60Hz
Core
Boost: 1455MHz/ Base: 1341MHz in OC Mode
Boost: 1430MHz/ Base: 1316MHz in Gaming
WindForce 2x cooling system
The WindForce 2x cooling system features two unique blade fans and semi-passive 3D active fan together delivering an effective heat dissipation capacity for higher performance at lower temperatures. -
Unique blade fan design
The airflow is spilt by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow. -
3D active fan
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle. -
One-click super overclocking
With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment. -
Ultra-cooling
Lower RDS MOSFETs are specially designed to produce lower switching resistance for faster electric current charging and discharging at extremely low temperature. -
Low power loss
Metal choke hold energy much longer than common iron-core chokes at high frequency, thus effectively reduce core energy loss and EMI interference. -
Longer life
Lower ESR solid capacitors ensure better electronic conductivity for excellent system performance and longer lifespan. -
Intuitive XTREME engine utility
Clock speeds, voltage, fan performance, power target can be monitored and tuned in real-time according to your own preference through this intuitive interface.
- Gigabyte GeForce GTX 1050 Ti OC 4G - graphics card - GF GTX 1050 Ti - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1050 Ti
- Memory
- 4 GB GDDR5
- Core Clock
- 1341 MHz
- Boost Clock
- 1455 MHz
- Effective Memory Clock
- 7.008 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 7680 x 4320
- Max Resolution Details
- DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
- Max Monitors Supported
- 3
- DVI-D (dual link) , DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 3.6 cm x 19.1 cm x 11.1 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1341 MHz
- Boost Clock
- 1455 MHz
- Process Technology
- 16 nm
- Max Resolution
- 7680 x 4320 at 60 Hz
- 3
- API Supported
- Ultra Durable 2, GIGABYTE WindForce 2x, NVIDIA G-Sync ready, NVIDIA GameWorks, 80mm Unique blade fan design
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.008 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 300 W
- 3.6 cm
- 19.1 cm
- 11.1 cm
