Gigabyte GeForce GTX 1050 Ti OC 4GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: CGHVWS00 Mfr#: GV-N105TOC-4GD
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
14 in stock
£123.46 ex VAT
£148.15 inc VAT
GEFORCE GTX 1050
ESSENTIAL GEAR FOR EVERY GAMER
Everyone deserves great gaming. That’s why we created the fast, powerful GeForce® GTX 1050. Now, you can turn your PC into a true gaming rig, powered by NVIDIA Pascal™—the most advanced GPU architecture ever created. It’s loaded with innovative NVIDIA Game Ready technologies that let every gamer experience the latest titles in their full glory. #GameReady.
Powered by GeForce® GTX 1050 Ti
Integrated with 4GB GDDR5 128bit memory
WINDFORCE 2X with Blade Fan Design
Support up to 8K display @60Hz
Core
Boost: 1455MHz/ Base: 1341MHz in OC Mode
Boost: 1430MHz/ Base: 1316MHz in Gaming
  • WindForce 2x cooling system
    The WindForce 2x cooling system features two unique blade fans and semi-passive 3D active fan together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
  • Unique blade fan design
    The airflow is spilt by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow.
  • 3D active fan
    The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle.
  • One-click super overclocking
    With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment.
  • Ultra-cooling
    Lower RDS MOSFETs are specially designed to produce lower switching resistance for faster electric current charging and discharging at extremely low temperature.
  • Low power loss
    Metal choke hold energy much longer than common iron-core chokes at high frequency, thus effectively reduce core energy loss and EMI interference.
  • Longer life
    Lower ESR solid capacitors ensure better electronic conductivity for excellent system performance and longer lifespan.
  • Intuitive XTREME engine utility
    Clock speeds, voltage, fan performance, power target can be monitored and tuned in real-time according to your own preference through this intuitive interface.
Gigabyte GeForce GTX 1050 Ti OC 4G - graphics card - GF GTX 1050 Ti - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1050 Ti
4 GB GDDR5
Core Clock
1341 MHz
Boost Clock
1455 MHz
Effective Memory Clock
7.008 GHz
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Resolution Details
DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported
3
DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.6 cm x 19.1 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1341 MHz
Boost Clock
1455 MHz
Process Technology
16 nm
Max Resolution
3
API Supported
Ultra Durable 2, GIGABYTE WindForce 2x, NVIDIA G-Sync ready, NVIDIA GameWorks, 80mm Unique blade fan design
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.008 GHz
Bus Width
128-bit
Required Power Supply
300 W
3.6 cm
19.1 cm
11.1 cm
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce GTX 1050 Ti
Interface: PCI Express 3.0 x16
Memory Size: 4GB
Memory Size: 4GB
Digital Output: DisplayPort
Digital Output: Dual DVI
Digital Output: High-Definition Multimedia Interface (HDMI)
Brand: Gigabyte
Price Range Ex VAT: 100 - 150
