Gigabyte GeForce GTX 1050 Ti G1 GAMING 4GB GDDR5 PCIe3.0 Graphics
Quicklinx: CGHSWS00 Mfr#: GV-N105TG1-GAMING-4GD
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
42 in stock
£180.93 ex VAT
£217.11 inc VAT
GEFORCE GTX 1050
ESSENTIAL GEAR FOR EVERY GAMER
Everyone deserves great gaming. That’s why we created the fast, powerful GeForce® GTX 1050. Now, you can turn your PC into a true gaming rig, powered by NVIDIA Pascal™—the most advanced GPU architecture ever created. It’s loaded with innovative NVIDIA Game Ready technologies that let every gamer experience the latest titles in their full glory. #GameReady.
Powered by GeForce® GTX 1050 Ti
Integrated with 4GB GDDR5 128bit memory
WINDFORCE 2X with Blade Fan Design
16.8M Customizable Color RGB Lighting
Core
Boost: 1506 MHz/ Base: 1392 MHz in OC Mode
Boost: 1480 MHz/ Base: 1366 MHz in Gaming
GIGABYTE G1 Gaming Series graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary NVIDIA® Pascal™ GPU architecture, G1 gaming graphics card brings you incredible gaming experience.
- Pascal-powered graphics card give you superior performance and power efficiency
- Classic and modern games at 1080p @ 60 FPS
- Fast, smooth, power-efficient gaming experiences
WINDFORCE 2X Cooling System
The WINDFORCE 2X cooling system features two 90mm unique blade fans, 2 pure copper composite heat-pipes, alternate spinning fan design, and heat pipes direct touch technology, together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
Alternate Spinning Fan Design
Optimize air flow by the alternate spinning fans that reduce air turbulence and effectively dissipate the heat.
Unique Blade Fan Design
The airflow is spilt by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
16.8M Customizable Color Lighting
With 16.8M customizable color options and numerous lighting effects, you could now choose the right scheme for your gaming rig through XTREME Engine utility.
One-click Super overclocking
With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment.
  • Design
    This graphics card features an optimized air flow thanks to the alternate spinning fans that reduce air turbulence and effectively dissipate the heat.
  • Unique fan design
    The airflow is split by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow.
  • Composite heat pipes
    The composite heat pipes combine both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases the cooling capacity.
  • Protection back plate
    The back plate offers rigidity and protection to the structure, while adding a sleek, clean look to the product.
  • Durable components
    Engineered with quality chokes and capacitors, this graphics card delivers outstanding performance and durable system lifespan.
Gigabyte GeForce GTX 1050 Ti G1 Gaming 4G - OC Edition - graphics card - GF GTX 1050 Ti - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1050 Ti
4 GB GDDR5
Core Clock
1392 MHz
Boost Clock
1506 MHz
Effective Memory Clock
7.008 GHz
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Resolution Details
DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported
4
DVI-D (dual link) , DisplayPort , 3 x HDMI
API Supported
DirectX 12, OpenGL 4.5
4 cm x 21.9 cm x 11.8 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1392 MHz
Boost Clock
1506 MHz
Process Technology
16 nm
Max Resolution
4
API Supported
Ultra Durable VGA, LED indicator, GIGABYTE GPU Gauntlet Sorting, GIGABYTE WindForce 2x, NVIDIA G-Sync ready, NVIDIA GameWorks, Heat Pipe Direct Touch technology, 4+1 Phase Power Design
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.008 GHz
Bus Width
128-bit
Required Power Supply
300 W
Additional Requirements
6 pin PCI Express power connector
Backplate
Software Included
GeForce Experience, XTREME Engine Utility
4 cm
21.9 cm
11.8 cm
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce GTX 1050 Ti
Interface: PCI Express 3.0 x16
Memory Size: 4GB
Memory Size: 4GB
Digital Output: DisplayPort
Digital Output: Dual DVI
Digital Output: High-Definition Multimedia Interface (HDMI)
Brand: Gigabyte
Price Range Ex VAT: 150 - 300
