Product
Gigabyte GeForce GTX 1050 OC 2GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: CGHZWS00 Mfr#: GV-N1050OC-2GD
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce GTX 1050, NVIDIA GeForce GTX 1050, NVIDIA GeForce GTX 1050
Interface: PCI Express 3.0 x16
Memory Size: 2GB, 2GB
Digital Output: DisplayPort, Dual DVI, High-Definition Multimedia Interface (HDMI)
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
£110.05 ex VAT
£132.06 inc VAT
GEFORCE GTX 1050
ESSENTIAL GEAR FOR EVERY GAMER
Everyone deserves great gaming. That’s why we created the fast, powerful GeForce® GTX 1050. Now, you can turn your PC into a true gaming rig, powered by NVIDIA Pascal™—the most advanced GPU architecture ever created. It’s loaded with innovative NVIDIA Game Ready technologies that let every gamer experience the latest titles in their full glory. #GameReady.
Powered by GeForce® GTX 1050
Integrated with 2GB GDDR5 128bit memory
WINDFORCE 2X with Blade Fan Design
Support up to 8K display @60Hz
Core
Boost: 1518 MHz/ Base: 1404 MHz in OC Mode
Boost: 1493 MHz/ Base: 1379 MHz in Gaming
  • WINDFORCE 2X cooling system
    The WINDFORCE 2X cooling system features two 80 mm unique blade fans and semi-passive 3D active fan together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
  • 80 mm unique blade fan design
    The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
  • 3D active fan
    The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle.
  • One-click super overclocking
    With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment.
  • Ultra cooling
    Lower RDS(on) MOSFETs are specially designed to produce lower switching resistance for faster electric current charging and discharging at extremely low temperature.
  • Low power loss
    Metal Choke hold energy much longer than common iron-core chokes at high frequency, thus effectively reduce core energy loss and EMI interference.
  • Longer life
    Lower ESR Solid Capacitors ensure better electronic conductivity for excellent system performance and longer lifespan.
Gigabyte GeForce GTX 1050 OC 2G - graphics card - NVIDIA GeForce GTX 1050 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1404 MHz
Boost Clock
1518 MHz
Effective Memory Clock
7.008 GHz
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Resolution Details
DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported
3
DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.6 cm x 19.1 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1404 MHz
Boost Clock
1518 MHz
Process Technology
16 nm
Max Resolution
3
API Supported
Ultra Durable 2, GIGABYTE WindForce 2x, NVIDIA G-Sync ready, NVIDIA GameWorks, NVIDIA Pascal GPU technology, 80mm Unique blade fan design
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
7.008 GHz
Bus Width
128-bit
Required Power Supply
300 W
Software Included
GeForce Experience, XTREME Engine Utility
3.6 cm
19.1 cm
11.1 cm
Memory Size: 2GB
Memory Size: 2GB
Digital Output: Dual DVI
Digital Output: High-Definition Multimedia Interface (HDMI)
Brand: Gigabyte
Price Range Ex VAT: 100 - 150
