Gigabyte GA-X99-Designare EX Intel X99 S2011-3 DDR4 USB3.1 ATX
Quicklinx: C8P9WS00 Mfr#: GA-X99-Designare EX
  • Bluetooth 3.0
  • Bluetooth 4.0
  • IEEE 802.11n
In order to provide support for water cooling solutions, Gigabyte has equipped this motherboard with an additional water pump power header. This allows the user to have full control over two water pumps or fans.
  • Set the color that matches your style
    Offering more LED customizations, users can truly adapt their PC to represent their lifestyle. With full RGB support, the user has complete control over the LEDs which surround the motherboard.
  • Pure speed, more power
    The USB 3.1 controller utilizes four PCIe Gen3 lanes, offering high bandwidth, for uncompromised transfer speeds. The much improved USB 3.1 protocol is available over the reversible USB Type-C and the traditional USB Type-A connector for better compatibility over a wider range of devices.
  • Dual hybrid fan headers
  • Dual armor DIMM and PCIe metal shielding
    Never worry about your heavy graphics card damaging your motherboard again. Gigabyte's proprietary PCIe metal shielding reinforces the PCIe connector to prevent slot damage due to heavy graphics card. The DIMM and PCIe metal shield also provides extra strength.
  • Built-in performance tuning IC
    Thanks to the onboard Turbo B-Clock Tuning IC, this motherboard enables overclockers to have the ability to change their BCLK frequency to a desired value of their choice.
Gigabyte GA-X99-Designare EX - 1.0 - motherboard - ATX - LGA2011-v3 Socket - X99
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Core i7 Extreme Edition, Core i7
Max RAM Size
256 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, registered, unbuffered
Storage Ports
6 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2, 2 x U.2 port
USB / FireWire Ports
1 x USB-C + 1 x USB 3.1 + 5 x USB 3.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
Motherboard - ATX
Chipset Type
Intel X99 Express
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
256 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3600 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Registered, unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Details
256 GB - registered , 128 GB - unbuffered
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 3 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x8 mode) , 1 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode) , 1 x M.2 socket
Storage Interfaces
SATA-600 -connectors: 6 x 7pin SATA, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , PCIe 3.0 -connectors: 1 x M.2, 2 x U.2 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
2 x LAN (Gigabit Ethernet) , 5 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 1 x USB 3.1 , 1 x USB-C , 1 x DisplayPort
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
AutoGreen, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, On/Off Charge, Ultra Durable, Dual LAN Teaming, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ESD Protection, Easy RAID Installer, All IR digital power design, 2x Copper PCB, Q-Flash Plus, IR PowIRstage ICs, Durable Black Solid Caps, Turbo B-Clock, Ultra Durable PCIe Metal Shielding, Intel Turbo Boost Technology 3.0, RGB Ambient Surround LED, GIGABYTE Double Locking Bracket, Ultra Durable Memory Armor, Anti-Sulfur Design
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup
Plug and Play, ACPI 5.0
30.5 cm
24.4 cm
