In order to provide support for water cooling solutions, Gigabyte has equipped this motherboard with an additional water pump power header. This allows the user to have full control over two water pumps or fans.
Set the color that matches your style
Offering more LED customizations, users can truly adapt their PC to represent their lifestyle. With full RGB support, the user has complete control over the LEDs which surround the motherboard. -
Pure speed, more power
The USB 3.1 controller utilizes four PCIe Gen3 lanes, offering high bandwidth, for uncompromised transfer speeds. The much improved USB 3.1 protocol is available over the reversible USB Type-C and the traditional USB Type-A connector for better compatibility over a wider range of devices. -
Dual hybrid fan headers
In order to provide support for water cooling solutions, Gigabyte has equipped this motherboard with an additional water pump power header. This allows the user to have full control over two water pumps or fans. -
Dual armor DIMM and PCIe metal shielding
Never worry about your heavy graphics card damaging your motherboard again. Gigabyte's proprietary PCIe metal shielding reinforces the PCIe connector to prevent slot damage due to heavy graphics card. The DIMM and PCIe metal shield also provides extra strength. -
Built-in performance tuning IC
Thanks to the onboard Turbo B-Clock Tuning IC, this motherboard enables overclockers to have the ability to change their BCLK frequency to a desired value of their choice.
- Gigabyte GA-X99-Designare EX - 1.0 - motherboard - ATX - LGA2011-v3 Socket - X99
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- 1 x LGA2011-v3 Socket
- Compatible Processors
- Core i7 Extreme Edition, Core i7
- Max RAM Size
- 256 GB
- RAM Supported
- 8 DIMM slots - DDR4, non-ECC, registered, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 4 x SATA-600, 1 x SATA Express port, 1 x M.2, 2 x U.2 port
- USB / FireWire Ports
- 1 x USB-C + 1 x USB 3.1 + 5 x USB 3.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X99 Express
- Processor Socket
- LGA2011-v3 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 256 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3600 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Registered, unbuffered
- Intel Extreme Memory Profiles (XMP), quad channel memory architecture
- Details
- 256 GB - registered , 128 GB - unbuffered
Audio
- Audio Codec
- Realtek ALC1150
- High Definition Audio
LAN
- Network Interfaces
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 3 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x8 mode) , 1 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode) , 1 x M.2 socket
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin SATA, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , PCIe 3.0 -connectors: 1 x M.2, 2 x U.2 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
- 2 x LAN (Gigabit Ethernet) , 5 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 1 x USB 3.1 , 1 x USB-C , 1 x DisplayPort
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
- Hardware Features
- AutoGreen, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, On/Off Charge, Ultra Durable, Dual LAN Teaming, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ESD Protection, Easy RAID Installer, All IR digital power design, 2x Copper PCB, Q-Flash Plus, IR PowIRstage ICs, Durable Black Solid Caps, Turbo B-Clock, Ultra Durable PCIe Metal Shielding, Intel Turbo Boost Technology 3.0, RGB Ambient Surround LED, GIGABYTE Double Locking Bracket, Ultra Durable Memory Armor, Anti-Sulfur Design
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup
- Plug and Play, ACPI 5.0
- 30.5 cm
- 24.4 cm
