Product
Brand
Gigabyte GA-H110M-H DDR4 Intel H110 S1151 PCIe3.0 USB3.0 microATX
Quicklinx: BPSHWS00 Mfr#: GA-H110M-H
Processor Socket: LGA1151 Socket
Chipset: Intel H110 Express
Graphics: Graphics adapter (CPU required)
Form Factor: Micro ATX
Memory Support: DDR4 SDRAM
7 in stock
£41.26 ex VAT
£49.51 inc VAT
Standard delivery Delivered within 3-5 working days
  • Supports 6th Generation Intel® Core™ Processor
  • Dual Channel DDR4, 2 DIMMs
  • Audio Noise Guard with High Quality Audio Capacitors
  • HDMI 1.4, D-sub ports for multiple display
  • Realtek® GbE LAN with cFosSpeed Internet Accelerator Software
  • All new GIGABYTE™ APP Center, simple and easy use
  • Support Intel® Small Business Basics
GIGABYTE Ultra Durable ™ Motherboards
GIGABYTE 100 series motherboards support the latest 6th Generation Intel® Core™ processors, a 14nm desktop CPU which features improved performance, power efficiency and support for DDR4 memory, bringing cutting edge features and ultimate performance to your next PC build.
High Quality Onboard Audio Design
Delivers high quality sound resolution and sound expansion to create the most realistic sound effects for professional users.
  • High Quality Audio Capacitors
  • Audio Noise Guard
Humidity Protection with Glass Fabric PCB
There is nothing more harmful to the longevity of your PC than moisture, and most parts of the world experience moisture in the air as humidity at some point during the year. GIGABYTE motherboards have been designed to make sure that humidity is never an issue, incorporating a new Glass Fabric PCB technology that repels moisture caused by humid and damp conditions. Glass Fabric PCB technology uses a new PCB material which reduces the amount of space between the fiber weave, making it much more difficult for moisture to penetrate compared to traditional motherboard PCBs. This offers much better protection from short circuit and system malfunction caused by humid and damp conditions.
High ESD Ethernet & USB Port Protection
GIGABYTE motherboards raise the bar in terms of protecting your system, providing advanced electrostatic discharge (ESD) protection for both your Ethernet LAN and USB ports, both common sources of ESD-related failures. With pairing the dedicated protection filters, the Ethernet LAN and USB ports can withstand high electrostatic discharges, protecting your system from common electrical surges and even direct lighting strikes.
High Temperature Protection Lower RDS(on) MOSFETs Design
GIGABYTE motherboards use Low RDS(on) MOSFETs which reduce energy wastage through unnecessary residual heat dissipation. This all amounts to tangible energy savings which are beneficial for both end-users and the environment without impacting system performance.
Gigabyte GA-H110M-HD3 DDR4 - 1.0 - motherboard - micro ATX - LGA1151 Socket - H110
Motherboard - micro ATX
Chipset Type
Intel H110 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, DDR4L unbuffered
Storage Ports
4 x SATA-600, 1 x M.2
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel H110 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4, DDR4L
Bus Clock
1600 MHz, 1333 MHz
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
512 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 3 x PCIe 2.0 x1
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 4 x 7pin SATA, 1 x M.2
4 x USB 3.0 , 2 x USB 2.0 , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 1 x DisplayPort , 1 x HDMI , 1 x TOSLINK , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
Q-Flash, AutoGreen, Ultra Durable, Easy RAID Installer, 4K Ultra HD ready, Audio Noise Guard with Path Lighting, GIGABYTE Smart Switch, Intel Small Business Basics support
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup
Plug and Play, ACPI 5.0
24.4 cm
19 cm
Brand: Gigabyte
Price Range Ex VAT: 0 - 50
