Gigabyte GA-F2A88X-D3HP AMD FM2+ A88X DDR3 USB3.1 ATX
Quicklinx: C2NMWS00 Mfr#: GA-F2A88X-D3HP
  • Fast USB 3.1 with USB Type-C™ -The World’s Next Universal Connector
  • Supports AMD FM2+/FM2 A-series APU
  • Dual Channel DDR3, 4 DIMMs
  • 2-way CrossFire™ Multi-graphics support
  • Audio Noise Guard with High Quality Audio Capacitors
  • HDMI 1.4, Dual-link DVI-D, D-sub ports for Triple-Monitor support
  • All solid capacitors design
  • GIGABYTE UEFI DualBIOS™
  • All new GIGABYTE™ APP Center, simple and easy use
GIGABYTE Ultra Durable ™ Motherboards
GIGABYTE FM2+ series motherboards support the latest AMD A-series processor with integrated AMD Radeon™ R-series graphics which features improved performance, power efficiency and support native PCIe 3.0 interfaces, bringing cutting edge features and ultimate performance to your next PC build.
Fast USB 3.1 Solution
The latest USB 3.1 offers a staggering 10Gb/s transfer speed, 2x faster than USB 3.0 and backward compatibility with existing USB devices.
High Quality Onboard Audio Design
Delivers high quality sound resolution and sound expansion to create the most realistic sound effects for professional users.
High Definition Digital Outputs
Enjoy true HD display capability using the most commonly integrated digital output technologies on today’s HD displays and TVs.
Dual-link DVI port
Designed to leverage the awesome potential of the latest AMD A-series APUs, GIGABYTE motherboards deliver an enhanced visual experience that includes advanced DX12® gaming, incredibly smooth HD multimedia playback and support for high resolution displays of up to 2560 x 1600 pixels by Dual-link DVI port.
HDMI Interface
HDMI is latest High-Definition Multimedia Interface, which is able to provide up to 5Gb/s video transmitting bandwidth and also 8-channel high quality audio. Via transmitting uncompressed digital data, HDMI is able to reduce signal interference as transferring between digital and analog signal, seen and heard, direct from the source. In addition, HDMI is compatible with HDCP (High-bandwidth Digital Content Protection), which allowing playback of Blu-ray/ HD DVD and other protected contents.
4K Ultra HD Support
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. GIGABYTE FM2+ series motherboards provide native 4K support with FM2+ APU integrated graphics via HDMI port.
AMD Dual Graphics Technology
The AMD FM2+ series platform showcases AMD Dual Graphics technology, allowing users to further boost 3D graphics performance by adding an additional discrete AMD Radeon™ graphics card to the system. This unique Dual Graphics technology means users can enjoy higher frame rates on the latest gaming titles, utilizing the processing power of both discrete and integrated graphics processors.
AMD Eyefinity Technology
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Multi-display support with AMD CrossFire
Flexible graphics capabilities - Up to 2 VGA cards are supported for 2 way AMD CrossFire™ (running at x16, x4 bandwidth), delivering the ultimate in graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution.
GIGABYTE Patented DualBIOS™ (UEFI) Design
GIGABYTE Ultra Durable™ motherboards feature GIGABYTE DualBIOS™, an exclusive technology from GIGABYTE that protects arguably one of your PC's most crucial components, the BIOS. GIGABYTE DualBIOS™ means that your motherboard has both a 'Main BIOS' and a 'Backup BIOS', making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process.
Humidity Protection with Glass Fabric PCB
There is nothing more harmful to the longevity of your PC than moisture, and most parts of the world experience moisture in the air as humidity at some point during the year. GIGABYTE motherboards have been designed to make sure that humidity is never an issue, incorporating a new Glass Fabric PCB technology that repels moisture caused by humid and damp conditions. Glass Fabric PCB technology uses a new PCB material which reduces the amount of space between the fiber weave, making it much more difficult for moisture to penetrate compared to traditional motherboard PCBs. This offers much better protection from short circuit and system malfunction caused by humid and damp conditions.
High ESD Ethernet & USB Port Protection
GIGABYTE motherboards raise the bar in terms of protecting your system, providing advanced electrostatic discharge (ESD) protection for both your Ethernet LAN and USB ports, both common sources of ESD-related failures. With pairing the dedicated protection filters, the Ethernet LAN and USB ports can withstand high electrostatic discharges, protecting your system from common electrical surges and even direct lighting strikes.
High Temperature Protection Lower RDS(on) MOSFETs Design
GIGABYTE motherboards use Low RDS(on) MOSFETs which reduce energy wastage through unnecessary residual heat dissipation. This all amounts to tangible energy savings which are beneficial for both end-users and the environment without impacting system performance.
  • Fast USB 3.1 solution
  • High quality onboard audio design
  • High definition digital outputs
    Enjoy true HD display capability using the most commonly integrated digital output technologies on today's HD displays and TVs.
  • Dual-link DVI port
    Designed to leverage the awesome potential of the latest AMD A-series APUs, GIGABYTE motherboards deliver an enhanced visual experience that includes advanced DX12 gaming, incredibly smooth HD multimedia playback and support for high resolution displays of up to 2560 x 1600 pixels by Dual-link DVI port.
  • HDMI interface
    HDMI is High-Definition Multimedia Interface, which is able to provide up to 5Gb/s video transmitting bandwidth and also 8-channel high quality audio. Via transmitting uncompressed digital data, HDMI is able to reduce signal interference as transferring between digital and analog signal, seen and heard, direct from the source. In addition, HDMI is compatible with HDCP (High-bandwidth Digital Content Protection), which allowing playback of Blu-ray/ HD DVD and other protected contents.
  • 4K Ultra HD support
  • Humidity protection with Glass Fabric PCB
    There is nothing more harmful to the longevity of your PC than moisture, and most parts of the world experience moisture in the air as humidity at some point during the year. GIGABYTE motherboards have been designed to make sure that humidity is never an issue, incorporating a Glass Fabric PCB technology that repels moisture caused by humid and damp conditions. Glass Fabric PCB technology uses a PCB material which reduces the amount of space between the fiber weave, making it much more difficult for moisture to penetrate compared to traditional motherboard PCBs. This offers much better protection from short circuit and system malfunction caused by humid and damp conditions.
  • High ESD Ethernet & USB port protection
Gigabyte GA-F2A88X-D3HP - 1.0 - motherboard - ATX - Socket FM2+ - AMD A88X
Motherboard - ATX
Chipset Type
AMD A88X
Processor Socket
1 x Socket FM2+
Compatible Processors
Athlon, A series
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR3
Storage Ports
8 x SATA-600 (RAID)
USB / FireWire Ports
1 x USB-C + 1 x USB 3.1 + 2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
AMD A88X
Processor Socket
Socket FM2+
Max Processors Qty
1
Athlon, A series
Supported RAM
Max Size
64 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz, 2400 MHz (O.C.)
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), AMD Memory Profile (AMP)
Graphics
2 GB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x PCIe 3.0 x16 (FM2+ processor must be installed) , 1 x PCIe 2.0 x16 (x4 mode) , 3 x PCIe 2.0 x1 , 2 x PCI , 4 x DIMM 240-pin , 1 x CPU
Storage Interfaces
SATA-600 -connectors: 8 x 7pin Serial ATA - 8 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 / JBOD
1 x PS/2 keyboard / mouse , 1 x VGA , 1 x DVI-D , 1 x HDMI , 2 x USB 3.0 , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK , 1 x USB-C , 1 x USB 3.1
Internal Interfaces
1 x SPDIF out - header , 1 x audio - header , 2 x USB 3.0 - header , 4 x USB 2.0 - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
DualBIOS, Q-Flash, All-Solid Capacitor motherboard Design, Intel Extreme Memory Profile (XMP) support, On/Off Charge, AMD Radeon Dual Graphics, Ultra Durable, AMD CrossFireX technology support, ESD Protection, AMD Eyefinity Technology, AMD Memory Profile (AMP) support, 4K Ultra HD ready, GIGABYTE Smart Switch, High Density Glass Fabric PCB, Audio Noise Guard
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, Smart TimeLock, GIGABYTE Game Controller
Plug and Play, ACPI 5.0
30.5 cm
23.5 cm
