Gigabyte GA-B150N PHOENIX WIFI S1151 B15 M-ITX
Quicklinx: BWMFWS00 Mfr#: GA-B150N-PHOENIX-WIFI
  • Bluetooth 4.0
  • Bluetooth 3.0
  • IEEE 802.11n
GIGABYTE Ultra Durable ™ Motherboards
GIGABYTE 100 series motherboards support the latest 6th Generation Intel® Core™ processors, a 14nm desktop CPU which features improved performance, power efficiency and support for DDR4 memory, bringing cutting edge features and ultimate performance to your next PC build.
Faster and Better Coverage with Intel® Dual Band 802.11ac WIfI + BT4.2 Module
The onboard 802.11ac WIFI module from Intel® supports up to 867 Mb/s wireless networks and BLUETOOTH 4.2. The bonded 2.4GHz/5GHz Dual Band and 2T2R antenna expands your coverage.
Fast Onboard Storage with 32Gb/s M.2
GIGABYTE M.2 solution offers considerably faster storage performance and support for both PCIe and SATA interface for M.2 SSD devices.
All New GIGABYTE App Center Including EasyTune™, Cloud Station™ Utilities and More...
GIGABYTE's EasyTune™ is a simple and easy-to-use interface that allows users to fine-tune their system settings or adjust system and memory clocks and voltages in a Windows environment. With Smart Quick Boost, one click is all it takes to automatically overclock your system, giving an added performance boost when you need it the most.
APP Center
GIGABYTE APP Center gives you easy access to a wealth of GIGABYTE APPs that help you get the most from your GIGABYTE motherboard. Using a simple, unified user interface, GIGABYTE APP Center allows you to launch all GIGABYTE APPs installed on your system.
Easy Tune™
Get the highest levels of performance from your PC with easy to use GIGABYTE overclocking features.
Cloud Station™
GIGABYTE Cloud Station™ is composed of several GIGABYTE unique apps that allow your smart phones/tablet devices to communicate, share resources, and control your desktop PC via a wireless connection.
Intel® GbE LAN with cFosSpeed
The Intel® Gigabit LAN with cFosSpeed features advanced technology to help deliver better network responsiveness in crowded LAN environments and allows optimization and improved network performance for specific applications, making it a popular choice amongst gamers.
Ambient LED
The GIGABYTE GA-B150N Phoenix-WIFI is equipped with exclusive Pulse LED lighting on the underside of the PCB, providing a signature look for any custom PC build. The soft-glowing orange lighting elegantly phases in and out during system operation, bringing the life to GIGABYTE B150N Phoenix-WIFI. GIGABYTE motherboards features LED lighting for the audio guard light path, providing a cool, custom look to your rig. These lights are now programmable, so you can have them beat to the rhythm of the music you are listening to, or pulse at a soothing pace to create a great atmosphere to enhance the environment of your game, movie or music.
High Quality Onboard Audio Design
Delivers high quality sound resolution and sound expansion to create the most realistic sound effects for professional users.
GIGABYTE Patented DualBIOS™ (UEFI) Design
GIGABYTE Ultra Durable™ motherboards feature GIGABYTE DualBIOS™, an exclusive technology from GIGABYTE that protects arguably one of your PC's most crucial components, the BIOS. GIGABYTE DualBIOS™ means that your motherboard has both a 'Main BIOS' and a 'Backup BIOS', making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process.
4K Ultra HD Support
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. GIGABYTE motherboards provide native 4K support with integrated Intel® HD Graphics via HDMI.
HDMI™ - The Next Generation Multimedia Interface
HDMI™ is a High-Definition Multimedia Interface which provides up to 5Gb/s video transmitting bandwidth and 8-channel high quality audio all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI™ ensures the crispest rendering of digital content up to 1080p without the quality losses associated with analog interfaces and their digital-to-analog conversion. In addition, HDMI™ is compatible with HDCP (High-bandwidth Digital Content Protection), allowing the playback of Blu-ray/HD DVD and other protected media content.
  • Fast USB 3.1 solution
    The USB 3.1 offers a staggering transfer speed, faster than USB 3.0 and backward compatibility with existing USB devices.
  • Faster and better coverage with 802.11ac Wi-Fi
    The onboard 802.11ac Wi-Fi module supports up to 867 Mb/s wireless networks and Bluetooth 4.2.
  • Fast onboard storage
    Gigabyte M.2 solution offers considerably faster storage performance and support for both PCIe and SATA interface for M.2 SSD devices.
  • Ambient LED
    Gigabyte motherboards feature LED lighting for the audio guard light path, providing a cool, custom look to your rig. These lights are programmable, so you can have them beat to the rhythm of the music you are listening to, or pulse at a soothing pace to create a great atmosphere to enhance the environment of your game, movie or music.
  • High-quality onboard audio design
    It delivers high-quality sound resolution and sound expansion to create the realistic sound effects for professional users.
  • DualBIOS design
    Gigabyte motherboards feature DualBIOS, an amazing technology from Gigabyte that protects arguably one of your PC's most crucial components, the BIOS. Gigabyte DualBIOS makes users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process.
Gigabyte GA-B150N Phoenix-WIFI - 1.0 - motherboard - mini ITX - LGA1151 Socket - B150
Motherboard - mini ITX
Chipset Type
Intel B150
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4 unbuffered
Storage Ports
4 x SATA-600, 1 x M.2
USB / FireWire Ports
1 x USB-C + 1 x USB 3.1 + 4 x USB 3.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Chipset Type
Intel B150
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2133 MHz
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
512 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Interfaces
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 1 x M.2 socket
Storage Interfaces
SATA-600 -connectors: 4 x 7pin SATA, 1 x M.2
1 x LAN (Gigabit Ethernet) , 1 x TOSLINK , 1 x HDMI , 4 x USB 3.0 , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x USB-C , 1 x USB 3.1
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
Q-Flash, AutoGreen, Ultra Durable, 4K Ultra HD ready, Audio Noise Guard with Path Lighting, GIGABYTE Smart Switch, GIGABYTE Ambient LED
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup
Plug and Play, ACPI 5.0
17 cm
17 cm
