Gigabyte GA-B150M-DS3H DDR4 Socket LGA1151 VGA DVI-D HDMI Micro ATX
Quicklinx: C5DKWS00 Mfr#: GA-B150M-DS3H
GIGABYTE 100 series motherboards support the latest 6th Generation Intel® Core™ processors, a 14nm desktop CPU which features improved performance, power efficiency and support for DDR4 memory, bringing cutting edge features and ultimate performance to your next PC build.
Fast Onboard Storage with 32Gb/s M.2
GIGABYTE M.2 solution offers considerably faster storage performance and support for both PCIe and SATA interface for M.2 SSD devices.
All New GIGABYTE App Center Including EasyTune™, Cloud Station™ Utilities and More...
GIGABYTE's EasyTune™ is a simple and easy-to-use interface that allows users to fine-tune their system settings or adjust system and memory clocks and voltages in a Windows environment. With Smart Quick Boost, one click is all it takes to automatically overclock your system, giving an added performance boost when you need it the most.
APP Center
GIGABYTE APP Center gives you easy access to a wealth of GIGABYTE APPs that help you get the most from your GIGABYTE motherboard. Using a simple, unified user interface, GIGABYTE APP Center allows you to launch all GIGABYTE APPs installed on your system.
Easy Tune™
Get the highest levels of performance from your PC with easy to use GIGABYTE overclocking features.
Cloud Station™
GIGABYTE Cloud Station™ is composed of several GIGABYTE unique apps that allow your smart phones/tablet devices to communicate, share resources, and control your desktop PC via a wireless connection.
Realtek Green GbE LAN with cFosSpeed Internet Accelerator Software
Realtek Green GbE LAN features cFosSpeed, a network traffic management application which helps to improve network latency, maintain low ping times to delivery better responsiveness in a crowded LAN environments. Realtek Green GbE consumes significant less power when it’s in idle state in comparison with others.
High Quality Onboard Audio Design
Delivers high quality sound resolution and sound expansion to create the most realistic sound effects for professional users.
High Definition Digital Outputs
Enjoy true HD display capability using the most commonly integrated digital output technologies on today’s HD displays and TVs.
Gold Plated CPU Socket Design
GIGABYTE motherboards come equipped with a gold plated CPU socket, which means that enthusiasts can enjoy absolute reliability and longevity for the CPU socket overtime, without having any concerns about corroded pins or bad contacts.
GIGABYTE Patented DualBIOS™ (UEFI) Design
GIGABYTE Ultra Durable™ motherboards feature GIGABYTE DualBIOS™, an exclusive technology from GIGABYTE that protects arguably one of your PC's most crucial components, the BIOS. GIGABYTE DualBIOS™ means that your motherboard has both a 'Main BIOS' and a 'Backup BIOS', making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process.
4K Ultra HD Support
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. GIGABYTE motherboards provide native 4K support with integrated Intel® HD Graphics via HDMI.
HDMI™ - The Next Generation Multimedia Interface
HDMI™ is a High-Definition Multimedia Interface which provides up to 5Gb/s video transmitting bandwidth and 8-channel high quality audio all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI™ ensures the crispest rendering of digital content up to 1080p without the quality losses associated with analog interfaces and their digital-to-analog conversion. In addition, HDMI™ is compatible with HDCP (High-bandwidth Digital Content Protection), allowing the playback of Blu-ray/HD DVD and other protected media content.
  • EasyTune technology
    Get the highest levels of performance from your PC with easy-to-use Gigabyte overclocking features.
  • High-quality onboard audio design
    This motherboard delivers high-quality sound resolution and sound expansion to create the incredibly realistic sound effects for professional users.
  • High-definition digital outputs
    Enjoy true high-definition display capability using the advanced digital output technologies.
  • Gold-plated CPU socket design
    Gigabyte motherboards come equipped with a gold-plated CPU socket, which means that enthusiasts can enjoy absolute reliability and longevity for the CPU socket overtime, without having any concerns about corroded pins or bad contacts.
  • Gigabyte Dual BIOS design
    Dual BIOS is a powerful technology from Gigabyte that protects arguably one of your PC's most crucial components, the BIOS. It means that your motherboard has a main BIOS and a backup BIOS, making users protected from BIOS failure due to a virus attack, a hardware malfunction, improper settings or a power failure during the update process.
  • HDMI support
    HDMI is an advanced multimedia interface which provides high video transmitting bandwidth and audio of superb quality - all through a single cable. Able to transmit superior, uncompressed digital video and audio, HDMI ensures the crisp rendering of digital content without the quality losses associated with analog interfaces and their digital-to-analog conversion. In addition, HDMI allows the playback of Blu-ray and other protected media content.
Gigabyte GA-B150M-DS3H - 1.0 - motherboard - micro ATX - LGA1151 Socket - B150
Motherboard - micro ATX
Chipset Type
Intel B150
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4 unbuffered
Storage Ports
6 x SATA-600, 1 x M.2
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel B150
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
512 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin Serial ATA, 1 x M.2
1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x HDMI , 4 x USB 3.0 , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard / mouse , 1 x DVI-D
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header , 1 x parallel - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
Q-Flash, AutoGreen, Ultra Durable, Intel Small Business Advantage support, Easy RAID Installer, Audio Noise Guard with Path Lighting, Clear CMOS Button, GIGABYTE Smart Switch
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup
Plug and Play
22.6 cm
19.3 cm
