GA-AX370-Gaming K5
Supports AMD Ryzen™ & 7th Generation A-series / Athlon™ Processors
Dual Channel Non-ECC Unbuffered DDR4, 4 DIMMs
Turbo B-Clock, Built-in Advanced Performance Tuning IC
Fast 4 USB 3.1 Gen 2 with USB Type-C™ and Type-A
2-Way CrossFire™/SLI™ Multi-Graphics Support with Dual Armor and Ultra Durable™ Design
Ultra-Fast PCIe Gen3 x4 M.2 with PCIe NVMe & SATA mode support
ALC 1220 120dB SNR HD Audio with Smart Headphone Amp
Intel® Gigabit LAN with cFosSpeed Internet Accelerator Software
USB DAC-UP 2 & 2 Front USB 3.0 Ports with Adjustable Voltage
RGB FUSION with Multi-Zone LED Light Show design
Swappable Overlay for Accent LED
Smart Fan 5 features 6 Temperature Sensors and 5 Hybrid Fan Headers
GIGABYTE™ UEFI DualBIOS™
APP Center Including EasyTune™ and Cloud Station™ Utilities
Surround lighting
Offering more LED customizations, you can truly adapt your PC to represent your own lifestyle. With RGB support, the user has complete control over the LEDs which surround the motherboard. -
Hybrid fan headers
Hybrid fan headers can automatically detect the type of cooling device whether it be fan or pump with different PWM or voltage mode. -
Ambient LED
Ambient lights are programmable. You can have them beat to the rhythm of the music you are listening to, or pulse at a soothing pace to create an atmosphere that enhances the environment of your game, movie or music. -
Smart headphone amp
Automatically detects impedance of your head-worn audio device, whether earbuds or quality headphones to provide optimal audio dynamics - preventing issues such as low volume and distortion. -
Durable memory armor
Exclusive one-piece, stainless-steel shielding design prevents against PCB distortion and twist, plate bending, in addition to preventing any possible ESD interference. -
Anti-sulfur resistor design
Sulfur compounds in the air can penetrate tiny on-board resistors creating chemical change and causing these resistors to open or short. If either of these occurs the motherboard will fail to function. By equipping resistors with an anti-sulfur design Gigabyte makes motherboards much more durable.
- Gigabyte GA-AX370-Gaming K5 - 1.0 - motherboard - ATX - Socket AM4 - AMD X370
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD X370
- Processor Socket
- 1 x Socket AM4
- Compatible Processors
- Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4 unbuffered
- Storage Ports
- 8 x SATA-600 (RAID), 2 x SATA Express port, 1 x M.2
- USB / FireWire Ports
- USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2 1 x USB-C Gen 2 + 3 x USB 3.1 Gen 2 + 6 x USB 3.1 Gen 1 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 2 GB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD X370
- Processor Socket
- Socket AM4
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz, 2667 MHz, 2933 MHz (O.C.), 3200 MHz (O.C.)
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Graphics
- 2 GB
Audio
- Audio Codec
- Realtek ALC1220
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode (x8 mode if neighbour x16 slot is occupied)) , 1 x PCIe 3.0 x16 (x8 mode) , 1 x PCIe 2.0 x16 (x4 mode (x2 mode if PCI Express 2.0 x1 slots is occupied)) , 3 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 8 x 7pin SATA, 2 x SATA Express port - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
- 1 x LAN (Gigabit Ethernet) , 6 x USB 3.1 Gen 1 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK , 1 x USB-C Gen2 , 3 x USB 3.1 Gen 2 , 1 x HDMI , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
- Hardware Features
- Diagnostic LEDs, Q-Flash, AutoGreen, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, On/Off Charge, Ultra Durable, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, Turbo B-Clock, Game Boost, RGB Ambient Surround LED, GIGABYTE Double Locking Bracket, Ultra Durable Memory Armor, Anti-Sulfur Design, GIGABYTE USB DAC-UP 2, GIGABYTE Smart Fan 5, RGB FUSION, Ultra Durable PCIe Armor, RGBW/-UV LED strips support
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup, GIGABYTE Smart Fan 5, GIGABYTE 3D OSD
- Plug and Play
- 30.5 cm
- 24.4 cm
