Gigabyte GA-AX370-GAMING 5 Motherboard
- Supports New Generation AMD Ryzen™ Processors
- Dual Channel Non-ECC Unbuffered DDR4, 4 DIMMs
- Fast 4 USB 3.1 Gen 2 with USB Type-C™ and Type-A
- 2-Way Graphics Support with Dual Armor and Ultra Durable™ Design
- NVMe PCIe Gen3 x4 U.2 Connector
- Ultra-Fast PCIe Gen3 x4 M.2 with PCIe NVMe & SATA mode support
- Creative® Sound Blaster X-Fi MB5 support
- Dual ALC 1220 with Front & Rear 120dB SNR HD Audio with Dual Smart Headphone Amps
- Killer™ E2500 Gaming Network + Intel® Gigabit LAN
- USB DAC-UP 2 & 4 Front USB 3.0 Ports with Adjustable Voltage
- RGB FUSION with Multi-Zone LED Light Show design
- Swappable Overlay for Accent LED
- Smart Fan 5 features 9 Temperature Sensors and 8 Hybrid Fan Headers
- 2 External Thermistors Headers with 2 Included Thermistors
- GIGABYTE UEFI DualBIOS™
- APP Center Including EasyTune™ and Cloud Station™ Utilities
Surround lighting
Offering more LED customizations, users can truly adapt their PC to represent their lifestyle. With full RGB support, the user has complete control over the LEDs which surround the motherboard. -
Swappable overlay for accent LED
Bringing even more color and life to your system with an accent LED overlay. This overlay complements the RGB Fusion technology in these motherboards adding more flare and style to your gaming machine. With the swappable overlay users can utilize different patterns and designs to make their system their own. -
Smart Fan 5
With Smart Fan 5 users can ensure that their gaming PC can maintain its performance while staying cool. Smart Fan 5 allows users to interchange their fan headers to reflect different thermal sensors at different locations on the motherboard. Not only that, with Smart Fan 5 more hybrid fan headers that support both PWM and voltage mode fans have been introduced to make the motherboard more liquid cooling friendly. -
Hybrid fan pin headers
Hybrid fan headers can automatically detect the type of cooling device whether it be fan or pump with different PWM or voltage mode. -
HD audio
These motherboards offer a high-performance, multi-channel audio codec, ensuring users get great audio quality from their PC. -
Adcanced audio capacitors
These motherboards use advanced audio capacitors. These high-quality capacitors help deliver high-fidelity audio to provide realistic sound effects for gamers.
- Gigabyte GA-AX370-Gaming 5 - 1.0 - motherboard - ATX - Socket AM4 - AMD X370
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD X370
- Processor Socket
- 1 x Socket AM4
- Compatible Processors
- Ryzen
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, ECC, unbuffered
- Storage Ports
- 8 x SATA-600 (RAID), 2 x SATA Express port, 1 x M.2, 1 x U.2 port
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 3 x USB 3.1 Gen 2 + 6 x USB 3.1 Gen 1 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 2 GB
- Audio
- HD Audio (8-channel)
- LAN
- 2 x Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD X370
- Processor Socket
- Socket AM4
- Max Processors Qty
- 1
- Ryzen
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz, 2667 MHz, 2933 MHz (O.C.), 3200 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC, ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 2 GB
Audio
- Audio Codec
- 2x Realtek ALC1220
- High Definition Audio
LAN
- Network Interfaces
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode (x8 mode if neighbour x16 slot is occupied)) , 3 x PCIe 2.0 x1 , 1 x PCIe 3.0 x16 (x8 mode) , 1 x PCIe 2.0 x16 (x4 mode (x1/x2 mode if PCI Express 2.0 x1 slots is occupied))
- Storage Interfaces
- SATA-600 -connectors: 8 x 7pin SATA, 2 x SATA Express port - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x U.2
- 2 x LAN (Gigabit Ethernet) , 6 x USB 3.1 Gen 1 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK , 1 x USB-C Gen2 , 3 x USB 3.1 Gen 2 , 1 x HDMI , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x SPDIF out - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
- Hardware Features
- Diagnostic LEDs, Q-Flash, AutoGreen, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, On/Off Charge, Ultra Durable, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, Black Solid Capacitors, Game Boost, RGB Ambient Surround LED, GIGABYTE Double Locking Bracket, Ultra Durable Memory Armor, Anti-Sulfur Design, G-Connector, GIGABYTE USB DAC-UP 2, GIGABYTE Smart Fan 5, RGB FUSION, Ultra Durable PCIe Armor, RGBW/-UV LED strips support, 6 + 4 Digital Phase Power Design
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup, GIGABYTE 3D OSD, Creative Sound Blaster X-Fi MB5
- Plug and Play
- 30.5 cm
- 24.4 cm
