GA-AB350M-HD3
Supports AMD Ryzen™ & 7th Generation A-series/ Athlon™ Processors
Dual Channel Non-ECC Unbuffered DDR4, 2 DIMMs
Fast 2 USB 3.1 Gen 2 with USB Type-A
2-Way CrossFire™ Multi-Graphics Support
Ultra-Fast PCIe Gen3 x4 M.2 with PCIe NVMe & SATA mode support
High Quality Audio Capacitors and Audio Noise Guard with LED Trace Path Lighting
Realtek® Gigabit LAN with cFosSpeed Internet Accelerator Software
Smart Fan 5 features 5 Temperature Sensors and 2 Hybrid Fan Headers
GIGABYTE UEFI DualBIOS™
APP Center Including EasyTune™ and Cloud Station™ Utilities
Smart Fan 5
With Smart Fan 5 users can ensure that their gaming PC can maintain its performance while staying cool. Smart Fan 5 allows users to interchange their fan headers to reflect different thermal sensors at different locations on the motherboard. Not only that, with Smart Fan 5 more hybrid fan headers that support both PWM and Voltage mode fans have been introduced to make the motherboard more liquid cooling friendly. -
Enhanced BIOS interface
The enhanced BIOS interface also has the advanced features seen in the Smart Fan 5 UI, such as: the ability to set triggers based on different temperature sensors on the board, fan curve definition and the temperature interval setting, which can prevent fan rotation noise caused by sudden temperature change - all without having to load Windows. -
NVMe PCIe Gen3 x4 2280 M.2 connector
GIGABYTE M.2 solution offers considerably faster storage performance and support for both PCIe and SATA interface for M.2 SSD devices. -
Fast USB 3.1 Gen 2 solution
The USB 3.1 Gen 2 offers staggering 10 Gb/s transfer speeds. Faster than USB 3.1 Gen 1 along with backwards compatibility with existing USB devices. -
Anti-sulfur resistor design
Sulfur compounds in the air can penetrate tiny onboard resistors creating chemical change and causing these resistors to open or short. If either of these occurs the motherboard will fail to function. -
High-quality onboard audio design
Delivers high-quality sound resolution and sound expansion to create realistic sound effects for professional gamers. -
Humidity protection Glass Fabric PCB
There is nothing more harmful to the longevity of your PC than moisture, and most parts of the world experience moisture in the air as humidity at some point during the year. GIGABYTE motherboards have been designed to make sure that humidity is never an issue, incorporating a Glass Fabric PCB technology that repels moisture caused by humid and damp conditions. Glass Fabric PCB technology uses the PCB material which reduces the amount of space between the fiber weave, making it much more difficult for moisture to penetrate compared to traditional motherboard PCBs. This offers much better protection from short circuit and system malfunction caused by humid and damp conditions. -
High temperature protection lower RDS MOSFETs design
GIGABYTE motherboards use low RDS MOSFETs which reduce energy wastage through unnecessary residual heat dissipation. This all amounts to tangible energy savings which are beneficial for both end-users and the environment without impacting system performance.
- Gigabyte GA-AB350M-HD3 - 1.0 - motherboard - micro ATX - Socket AM4 - AMD B350 FCH
- Product Type
- Motherboard - micro ATX
- Chipset Type
- AMD B350 FCH
- Processor Socket
- 1 x Socket AM4
- Compatible Processors
- Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
- Max RAM Size
- 32 GB
- RAM Supported
- 2 DIMM slots - DDR4, non-ECC, ECC (operate in non-ECC mode), unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 1 x M.2
- USB / FireWire Ports
- 2 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 2 GB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- AMD B350 FCH
- Processor Socket
- Socket AM4
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz, 2667 MHz, 2933 MHz (O.C.), 3200 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC, ECC (operate in non-ECC mode)
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), supported ECC modules operate in non-ECC mode
Graphics
- 2 GB
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode)
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
- 1 x LAN (Gigabit Ethernet) , 2 x USB 3.1 Gen 2 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x DVI-D , 1 x HDMI , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x VGA
- Internal Interfaces
- 4 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
- Hardware Features
- Q-Flash, AutoGreen, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Ultra Durable, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, Audio Noise Guard with Path Lighting, Game Boost, GIGABYTE Double Locking Bracket, Anti-Sulfur Design, GIGABYTE Smart Fan 5
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup, GIGABYTE 3D OSD
- Plug and Play
- 24.4 cm
- 21.5 cm
