Gigabyte GA-AB350-Gaming AMD B350 AM4 DDR4 M.2 USB3.1 ATX
Quicklinx: CR04WS00 Mfr#: GA-AB350-Gaming
Gigabyte GA-AB350-Gaming Motherboard
  • Supports New Generation AMD Ryzen™ Processors
  • Dual Channel Non-ECC Unbuffered DDR4, 4 DIMMs
  • Fast 2 USB 3.1 Gen 2 with USB Type-A
  • Ultra-Fast PCIe Gen3 x4 M.2 with PCIe NVMe & SATA mode support
  • High Quality Audio Capacitors and Audio Noise Guard with LED Trace Path Lighting
  • Realtek® Gigabit LAN with cFosSpeed Internet Accelerator Software
  • Smart Fan 5 features 6 Temperature Sensors and 4 Hybrid Fan Headers
  • GIGABYTE UEFI DualBIOS™
  • APP Center Including EasyTune™ and Cloud Station™ Utilities
  • Surround lighting
    Offering more LED customizations, users can truly adapt their PC to represent their lifestyle. With full RGB support, the user has complete control over the LEDs which surround the motherboard.
  • Swappable overlay for accent LED
    Bringing even more color and life to your system with an accent LED overlay. This overlay complements the RGB Fusion technology in these motherboards adding more flare and style to your gaming machine. With the swappable overlay users can utilize different patterns and designs to make their system their own.
  • Smart Fan 5
    With Smart Fan 5 users can ensure that their gaming PC can maintain its performance while staying cool. Smart Fan 5 allows users to interchange their fan headers to reflect different thermal sensors at different locations on the motherboard. Not only that, with Smart Fan 5 more hybrid fan headers that support both PWM and voltage mode fans have been introduced to make the motherboard more liquid cooling friendly.
  • Hybrid fan pin headers
    Hybrid fan headers can automatically detect the type of cooling device whether it be fan or pump with different PWM or voltage mode.
  • HD audio
    These motherboards offer a high-performance, multi-channel audio codec, ensuring users get great audio quality from their PC.
  • Adcanced audio capacitors
    These motherboards use advanced audio capacitors. These high-quality capacitors help deliver high-fidelity audio to provide realistic sound effects for gamers.
Gigabyte GA-AB350-Gaming - 1.0 - motherboard - ATX - Socket AM4 - AMD B350 FCH
Motherboard - ATX
Chipset Type
AMD B350 FCH
Processor Socket
1 x Socket AM4
Compatible Processors
Ryzen
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
USB 3.1 Gen 1, USB 3.1 Gen 2 2 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
AMD B350 FCH
Processor Socket
Socket AM4
Max Processors Qty
1
Ryzen
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2667 MHz, 2933 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), supported ECC modules operate in non-ECC mode
Graphics
2 GB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 3 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode (x2 mode if PCI Express 2.0 x1 slots is occupied))
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
1 x LAN (Gigabit Ethernet) , 2 x USB 3.1 Gen 2 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x DVI-D , 1 x HDMI , 4 x USB 3.1 Gen 1 , 2 x USB 2.0
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
Hardware Features
Q-Flash, AutoGreen, On/Off Charge, Ultra Durable, Audio Noise Guard with Path Lighting, Game Boost, GIGABYTE Double Locking Bracket, Anti-Sulfur Design, GIGABYTE Smart Fan 5
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup, GIGABYTE 3D OSD
Plug and Play
30.5 cm
22.5 cm
