The 990XA-UD3 R5 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the GIGABYTE unique technologies. Featuring the USB 3.0 controller, this motherboard allows users to take advantage of super fast USB transfer rates. Utilizing the serial ATA Revision 3.0 solution via AMD SB950 chipset, the GIGABYTE motherboard offers native 6 ports of next generation high speed data storage devices support with high data transfer speeds. The GA-990XA-UD3 R5 introduces an ultimate hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery.
Extreme multi-GPU support
Flexible graphics capabilities supported for either 2-way CrossFire or 2-way SLI action, delivering an ultimate graphics performance for gaming enthusiasts who demand high frame rates without compromising on resolution. -
Realtek ALC1150 115 dB SNR HD audio with built-in rear audio amplifier
The Realtek ALC1150 is a high-performance multi-channel HD audio codec that delivers an exceptional audio listening experience with up to 115 dB SNR, ensuring users get exciting audio quality from their PC. Two stereo ADCs are integrated and can support a microphone array with Acoustic Echo Cancellation (AEC), Beam Forming (BF), and Noise Suppression (NS) technologies. The ALC1150 incorporates Realtek proprietary converter technology to achieve front differential output 115 dB signal-to-noise ratio (SNR), playback (DAC) quality and 104 dB SNR recording (ADC) quality. -
High quality audio capacitors
GIGABYTE Ultra Durable motherboard uses high quality Nippon Chemicon ARE series audio capacitors. These professional audio capacitors deliver a super high quality sound resolution and sound expansion to create realistic sound effects for user experience. -
2x copper PCB design
GIGABYTE's exclusive 2x copper PCBs design provides sufficient power trace paths between components to handle greater than normal power loads and to remove heat from the critical CPU power delivery area. It is essential to ensure the motherboard is able to handle the increased power loading that is necessary when overclocking. -
Long lifespan solid capacitors
GIGABYTE motherboard integrates the absolute quality solid state capacitors that are rated to perform at maximum efficiency for extended periods, even in extreme performance configurations. This provides peace of mind for end users who want to push their system hard, yet demand absolute reliability and stability. -
GIGABYTE patented DualBIOS (UEFI) design
GIGABYTE Ultra Durable motherboard features GIGABYTE DualBIOS, an exclusive technology from GIGABYTE that protects arguably one of your PC's crucial components, the BIOS. GIGABYTE DualBIOS means that your motherboard has both a main BIOS and a backup BIOS, making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process. -
ESD Protection for USB and LAN
GIGABYTE motherboard raises the bar in terms of protecting your system, providing advanced electrostatic discharge (ESD) protection for both your Ethernet LAN and USB ports, both common sources of ESD-related failures. Each LAN and USB port is paired with a dedicated protection filter that can withstand high electrostatic discharges, protecting your system from common electrical surges and even direct lighting strikes. -
Power failure protection with Anti-Surge IC
GIGABYTE Ultra Durable motherboard also features special anti-surge ICs that protect your motherboard, and your PC from any surge in power delivery that may occur, helping to ensure that your PC is equipped to deal with any potentially irregular and inconsistent power delivery. -
Alternative heat sink design
GIGABYTE motherboard features an alternative heat sink design that offers uncompromisingly efficient cooling on key areas of the motherboard including the PWM area and chipset (PCH). GIGABYTE motherboard offers cooling support of the crucial PWM area so even very aggressive and extreme configurations will be kept well within optimal thermal parameters.
- Gigabyte GA-990XA-UD3 R5 - 1.0 - motherboard - ATX - Socket AM3+ - AMD 990X
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD 990X / AMD SB950
- Processor Socket
- 1 x Socket AM3+
- Compatible Processors
- Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Athlon II, Phenom II X4, Phenom II X6
- Data Bus Transfer Rate
- 5.2 GT/s
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3
- Storage Ports
- 6 x SATA-600 (RAID)
- USB / FireWire Ports
- 2 x USB 3.0 + 8 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- 5.2 GT/s
- Processor Socket
- Socket AM3+
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2000 MHz (O.C.)
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- Realtek ALC1150
- High Definition Audio, Dolby Home Theater
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 2.0 x16 (x16 mode (x8 mode if neighbour slot is occupied)) , 1 x PCIe 2.0 x16 (x8 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe 2.0 x1 , 2 x PCI
- Storage Interfaces
- AMD SB950: SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 / JBOD
- 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 8 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
- Internal Interfaces
- 1 x SPDIF out - header , 6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x serial - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, power supply fan tachometer
- Hardware Features
- DualBIOS, Q-Flash, NVIDIA SLI Technology Support, 8+2 Phase Power Design, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Fanless Design Heatsink, Ultra Durable, AMD CrossFireX technology support, ESD Protection, Dedicated Audio Hardware Zone, Anti-Surge IC
- Software Included
- Norton Internet Security, @BIOS, EasyTune, Xpress Install
- Plug and Play, ACPI 5.0
- 30.5 cm
- 24.4 cm
