By combining a microATX format with the Intel Xeon processors E3-1200 V3 family and all its wonderful technologies, this board is a versatile solution for SMBs and independent professionals to build affordable yet high performing systems within compact rack or tower enclosures. From a mainstream intranet system performing standard tasks like file or print serving, a web server dedicated to a low traffic websites, a basic engineering or content creation workstation, to the building block of a computing grid or a render farm, the possibilities offered by this model equal its performance capabilities and make it a perfect candidate for a high value acquisition.
Intel Xeon processor product family
Still based on the 22nm tri-gate lithography, this Xeon processors generation is built on Intel's latest microarchitecture and brings more computing power improvements and increased L3 cache across the line. In addition, this product generation also brings to the Xeon E3 family the support of 1600MHz ECC memory, Intel Trusted Execution and Virtualization technologies, as well as AVX 2.0 and TSX instructions. Last but not least, the Xeon E3-1200 V3 processors include stunning Intel integrated graphics, which will bring the support of OGL3.2+, DirectX 11.1, and higher frequencies. -
LAN controller
In addition to overall performance and error correcting improvements, the power consumption has been reduced thanks to the on-chip integration of switching voltage regulators improving the efficiency of the power delivery to the controller.This controller also received additional audio/video bridging features, notably time-stamping and synchronization of time sensitive applications through traffic shaping, time-based transmission, and precision time-stamping. Two more management functions are also included, with the support of common transport for LAN-to-BMC / local OS-to-BMC and standards-based transport for BMC-to-adapter communication. -
Support of PCIe Generation 3.0
With the support of the PCI Express Gen.3.0 technology directly on the CPU, the GA-6LASL is fully configured to provide users with dramatically reduced latency and improved data bandwidth to get much.
- Gigabyte GA-6LASL - 1.0 - motherboard - micro ATX - LGA1150 Socket - C222
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel C222
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Core i3, Xeon E3-1200 v3 series
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, ECC, unbuffered
- Storage Ports
- 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
- USB / FireWire Ports
- 6 x USB 2.0 + (1 x USB 3.0 via headers)
- Graphics
- ASPEED AST1300
- LAN
- 2 x Gigabit Ethernet
- Product Type
- Chipset Type
- Intel C222
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz
- Supported RAM Integrity Check
- ECC
- Registered or Buffered
- Unbuffered
Graphics
- Graphics Controller
- ASPEED AST1300
LAN
- Network Controller
- Intel I210-AT
- Network Interfaces
- Expansion Slots
- 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x8 (x4 mode) , 1 x PCIe 2.0 x4 (x1 mode) , 1 x CPU
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- 1 x VGA , 1 x serial , 4 x USB 2.0 , 2 x LAN (Gigabit Ethernet)
- Internal Interfaces
- 1 x serial - header , 1 x USB 3.0 - header , 2 x USB 2.0 - Type A
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- IPMI support
- Hardware Features
- Clear CMOS Button
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- 24.4 cm
- 24.4 cm
