Designed to over perform in all kind of mission critical applications, whether they are computing and memory intensive, highly parallel, relying on storage or depending on expansions, the GA-7PESH4 is a versatile and highly reliable solution for your business.
The GA-7PESH4 includes Gigabyte's digital PWM controllers, guaranteeing a dynamic power supply to the processors and memory with an ultra-fast response time. Built with advanced calibration tools, they allow to get the pure and efficient electrical supply. When the CPU workloads vary in function of the applications running, the Intel Turbo Boost technology will do a dynamic overclock of the CPU cores. This is where the digital PWMs outshine the previous analog solutions. This way the CPUs operations are much more stable, and the overall reliability of the system is greatly improved.
Rock-solid backbone for critical server applications
Designed to over perform in all kind of mission critical applications, whether they are computing and memory intensive, highly parallel, relying on storage or depending on expansions, the GA-7PESH4 is a versatile and highly reliable solution for your business. -
High end quad GbE LAN solution
Built with the network controller, optimized for virtualization, iSCSI and management related traffic, the GA-7PESH4 is designed to free the processors as much as possible from the network transfer loadings. Intense transfers will typically occupy up to 30% less computing resources compared to traditional LAN solutions. Also consumes less energy thanks to EEE and DMA coordination. Supports OS2BMC and MCTP. -
Digital power control
The GA-7PESH4 includes Gigabyte's digital PWM controllers, guaranteeing a dynamic power supply to the processors and memory with an ultra-fast response time. Built with advanced calibration tools, they allow to get the pure and efficient electrical supply. When the CPU workloads vary in function of the applications running, the Intel Turbo Boost technology will do a dynamic overclock of the CPU cores. This is where the digital PWMs outshine the previous analog solutions. This way the CPUs operations are much more stable, and the overall reliability of the system is greatly improved. -
Unique memory performance
This board is an extremely high-value building block for demanding server applications, thanks to its ability to outperform its competitors in memory frequency. Achieved through Gigabyte's capabilities in design, PCB layout and BIOS fine-tuning, this feature will be appreciated in industries where each incremental improvement in performance results in significant benefits, such as in finance or HPC applications. -
Support of PCIe generation 3.0
With the support of the PCI Express generation 3.0 technology directly on the CPU, the GA-7PESH4 is fully configured to provide users with dramatically reduced latency and improved data bandwidth to get the most out of its expansion accessories. Moreover, it is built with a comprehensive variety of PCIe connectors to provide the flexible expansion platform to the user.
- Gigabyte GA-7PESH4 - 1.0 - motherboard - SSI EEB - LGA2011 Socket - C602
- Product Type
- Motherboard - SSI EEB
- Chipset Type
- Intel C602
- Processor Socket
- 2 x LGA2011 Socket
- Compatible Processors
- Xeon E5-2600 series
- Max RAM Size
- 512 GB
- RAM Supported
- DDR3, ECC, registered, unbuffered
- Storage Ports
- 8 x SAS (RAID), 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
- USB / FireWire Ports
- 5 x USB 2.0 + (1 x USB 2.0 via headers)
- Graphics
- ASPEED AST2300
- LAN
- 4 x Gigabit Ethernet
- Product Type
- Chipset Type
- Intel C602
- Processor Socket
- LGA2011 Socket
- Max Processors Qty
- 2
Supported RAM
- Max Size
- 512 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Supported RAM Integrity Check
- ECC
- Registered or Buffered
- Registered, unbuffered
- Quad channel memory architecture
- Details
- 512 GB - registered - ECC , 128 GB - unbuffered - ECC
Graphics
- Graphics Controller
- ASPEED AST2300
LAN
- Network Controller
- Intel I350
- Network Interfaces
- Expansion Slots
- 2 x CPU , 16 x DIMM 240-pin , 3 x PCIe 3.0 x16 , 2 x PCIe 3.0 x16 (x8 mode)
- Storage Interfaces
- SAS -connectors: 8 - 8 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- 4 x USB 2.0 , 1 x serial , 1 x VGA , 4 x LAN (Gigabit Ethernet)
- Internal Interfaces
- 1 x USB 2.0 - Type A , 1 x USB 2.0 - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- IPMI support, iKVM support
- Hardware Features
- Clear CMOS Button
- 33 cm
- 30.5 cm
