Your basket is empty
Gigabyte E-ATX SSI DIMM Intel Gbe
Quicklinx: B9LMWS00 Mfr#: GA-7PESH2
The GA-7PESH2 includes Gigabyte's digital PWM controllers, guaranteeing a dynamic power supply to the processors and memory with an ultra-fast response time. Built with advanced calibration tools, they allow to get the pure and efficient electrical supply. When the CPU workloads vary in function of the applications running, the Intel Turbo Boost technology will do a dynamic overclock of the CPU cores. This is where the digital PWMs outshine the previous analog solutions. This way the CPUs operations are much more stable, and the overall reliability of the system is greatly improved.
Gigabyte GA-7PESH2 - 1.0 - motherboard - SSI EEB - LGA2011 Socket - C602
Motherboard - SSI EEB
Chipset Type
Intel C602
Processor Socket
2 x LGA2011 Socket
Compatible Processors
Xeon E5-2600 series
Max RAM Size
512 GB
RAM Supported
16 DIMM slots - DDR3, ECC, registered, unbuffered
Storage Ports
8 x SAS2 (RAID), 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
2 x USB 2.0 + (2 x USB 2.0 via headers)
Graphics
ASPEED AST2300
LAN
2 x 10 Gigabit Ethernet
Chipset Type
Intel C602
Processor Socket
LGA2011 Socket
Max Processors Qty
2
Xeon E5-2600 series
Supported RAM
Max Size
512 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
ECC
Registered or Buffered
Registered, unbuffered
Quad channel memory architecture
Details
512 GB - registered - ECC , 128 GB - unbuffered - ECC
Graphics
Graphics Controller
ASPEED AST2300
LAN
Network Controller
Intel X540-AT2
Network Interfaces
Expansion Slots
2 x CPU , 16 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x8 mode) , 2 x PCIe 3.0 x8 (x4 mode) , 1 x PCIe 2.0 x4 (x1 mode)
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , LSI Logic LSISAS2008: SAS 2 - 8 devices - RAID 0 / RAID 1 / RAID 1E / RAID 10
2 x LAN (10Gigabit Ethernet) , 2 x USB 2.0 , 1 x VGA , 1 x management , 1 x serial
Internal Interfaces
2 x USB 2.0 - header
Power Connectors
24-pin main power connector, 2 x 8-pin ATX12V connectors
Hardware Features
Digital PWM, Intel Turbo Boost Technology
30.5 cm
33 cm
