Product
Brand
Gigabyte E-ATX SSI DIMM 10GB LAN
Quicklinx: B9LLWS00 Mfr#: GA-7PESH1
The GA-7PESH1 includes Gigabyte's digital PWM controllers, guaranteeing a dynamic power supply to the processors and memory with an ultra-fast response time. Built with advanced calibration tools, they allow to get the purest and most efficient electrical supply to date. When the CPU workloads vary in function of the applications running, the Intel Turbo Boost technology will do a dynamic overclock of the CPU cores. This is where the digital PWMs outshine the previous analog solutions. This way the CPUs operations are much more stable, and the overall reliability of the system is greatly improved.
Gigabyte has certified the GA-7PESH1 with Red Hat Enterprise Linux to provide its customers with the confidence of knowing that their hardware systems are supported by Red Hat when they run Red Hat Enterprise Linux.
Gigabyte GA-7PESH1 - 1.0 - motherboard - SSI EEB - LGA2011 Socket - C602
Motherboard - SSI EEB
Chipset Type
Intel C602
Processor Socket
2 x LGA2011 Socket
Compatible Processors
Xeon E5-1600 series, Xeon E5-2600 series
RAM Supported
16 DIMM slots - DDR3, non-ECC, ECC, registered, unbuffered
Storage Ports
8 x SAS2 (RAID), 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 2.0 + (2 x USB 2.0 via headers)
Graphics
ASPEED AST2300
LAN
2 x Gigabit Ethernet
Chipset Type
Intel C602
Processor Socket
LGA2011 Socket
Max Processors Qty
2
Supported RAM
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Registered, unbuffered
Quad channel memory architecture
Graphics
Graphics Controller
ASPEED AST2300
LAN
Network Controller
Intel I350
Network Interfaces
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , LSI Logic LSISAS2008: SAS 2 - 8 devices - RAID 0 / RAID 1 / RAID 1E / RAID 10
2 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x VGA , 1 x management , 1 x serial
Internal Interfaces
2 x USB 2.0 - header
Power Connectors
24-pin main power connector, 2 x 8-pin ATX12V connectors
BIOS Features
IPMI support
Hardware Features
Clear CMOS Button
I/O back plate
2 x Serial ATA cable
30.5 cm
33 cm
