This is an ultra compact PC with a stylish design based high polish surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, provides desktop miniaturization that makes it perfect as a discreet HTPC / multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact, versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough to sit in the palm of your hand. The Brix is engineered to take full advantage of what the hardware and its UEFI BIOS are capable of. And therefore, it's designed to deliver the extremely intuitive and integrated operating systems.
Redefining the desktop PC
This is an ultra compact PC with a stylish design based high polish surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, provides desktop miniaturization that makes it perfect as a discreet HTPC / multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact, versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough to sit in the palm of your hand. -
Powerful processor
Based on the Silvermot micro-architecture which, these SoC feature significant improvements in computational power, energy efficiency, enhanced graphical and media performance making the BRIX ideal for thin clients, retail transactional clients, and digital signage. -
Advanced features for power users
The Brix is engineered to take full advantage of what the hardware and its UEFI BIOS are capable of. And therefore, it's designed to deliver extremely intuitive and integrated operating systems.
 - Gigabyte BRIX GB-BACE-3150 (rev. 1.0) - Ultra Compact PC Kit - Celeron N3150 1.6 GHz - 0 GB - no HDD
 - PC barebone - Ultra Compact PC Kit - UEFI BIOS
- Processor
 - 1 x Intel Celeron N3150 / 1.6 GHz (, up to 2.08 GHz, (Quad-Core)
- Cache Memory
 - 2 MB
- Cache Per Processor
 - 2 MB
- RAM
 - 0 GB (installed) / 8 GB (max) - DDR3L SDRAM
- Storage Controller
 - SATA (SATA 6Gb/s)
- Hard Drive
 - No HDD
- Optical Storage
 - No optical drive
- Graphics Controller
 - Intel HD Graphics
- Audio Output
 - Stereo
- Networking
 - GigE
- Power
 - AC 120/230 V
- OS Provided
 - No operating system
 - 10.76 cm x 11.44 cm x 5.61 cm
 - PC barebone
- Product Form Factor
Processor / Chipset
- CPU
 - Intel Celeron N3150
- Clock Speed
 - 1.6 GHz
- Max Turbo Speed
 - 2.08 GHz
- Number of Cores
 - Quad-Core
- CPU Qty
 - 1
- Max CPU Qty
 - 1
Cache Memory
- Installed Size
 - 2 MB
 - 2 MB
RAM
- Installed Size
 - 0 GB / 8 GB (max)
- Technology
 - DDR3L SDRAM
- Form Factor
 - SO-DIMM 204-pin
- Slots
 - 1 (Total) / 1 (empty)
Hard Drive
 - No HDD
Storage Controller
 - 1 x SATA
- Controller Interface Type
 - SATA 6Gb/s
- Channel Qty
 - 1
Optical Storage
 - No optical drive
Monitor
- Monitor Type
 - None.
Graphics Controller
- Graphics Processor
 - Intel HD Graphics
- Video Interfaces
 - VGA, HDMI
- Max Monitors Supported
 - 2
Audio Output
- Sound Output Mode
 - Stereo
- Ethernet Controller
 - Realtek RTL8111H
- Data Link Protocol
- Bays
 - 1 (total) / 1 (free) x internal 2.5"
- Slots
 - 1 (total) / 1 (free) x SO-DIMM 204-pin , 1 PCIe Half Mini Card , 1 M.2 Card
 - 4 x USB 3.0 , 1 x HDMI , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Included Accessories
 - VESA wallmount adapter
 - UEFI BIOS
- Theft/Intrusion Protection
- VESA Mounting Interface
 - 100 x 100 mm, 75 x 75 mm
 - Power adapter
- Voltage Required
 - AC 120/230 V
Operating System / Software
- OS Provided
 - 10.76 cm
 - 11.44 cm
 - 5.61 cm
 - 0 °C
 - 35 °C
