Your basket is empty
Gigabyte BRIX Intel Celeron N3000 SO-DIMM DDR3L USB3.0 WiFi/BT PC
Quicklinx: BRRTWS00 Mfr#: GB-BACE-3000
Processor Type: Celeron
Operating System: No operating system
Installed Memory: 0MB
Hard Drive Capacity: 0GB
Storage Type: No HDD
  • Celeron
£99.30 ex VAT
£119.16 inc VAT
Challenging the essence of how you define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a stylish design based high polish surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact, versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough to sit in the palm of your hand.
Gigabyte BRIX GB-BACE-3000 (rev. 1.0) - Ultra Compact PC Kit - Celeron N3000 1.04 GHz - 0 MB - 0 GB
PC barebone - Ultra Compact PC Kit
1 x Intel Celeron N3000 / 1.04 GHz (2.08 GHz) (Dual-Core)
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
0 MB (installed) / 8 GB (max) - DDR3L SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
Card Reader
Graphics Controller
Intel HD Graphics
Audio Output
Stereo
GigE
AC 120/230 V
OS Provided
No operating system
10.76 cm x 11.44 cm x 5.61 cm
PC barebone
Product Form Factor
Processor / Chipset
CPU
Max Turbo Speed
2.08 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
0 MB / 8 GB (max)
DDR3L SDRAM
SO-DIMM 204-pin
Hard Drive
No HDD
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
1
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel HD Graphics
Video Interfaces
VGA, HDMI
Max Monitors Supported
2
Audio Output
Sound Output Mode
Stereo
Ethernet Controller
Realtek RTL8111H
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x SO-DIMM 204-pin , 1 M.2 Card
4 x USB 3.0 , 1 x HDMI , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x headphones - mini-jack , 1 x microphone - mini-jack
VESA wallmount adapter
UEFI BIOS
Theft/Intrusion Protection
Mounting Interface
100 x 100 mm, 75 x 75 mm
Power adapter
Nominal Voltage
AC 120/230 V
Operating System / Software
OS Provided
No operating system
10.76 cm
11.44 cm
5.61 cm
35 °C
Gigabyte BRIX Intel Celeron N3000 SO-DIMM DDR3L USB3.0 WiFi/BT PC Bundle deal on Gigabyte BRIX Intel Celeron N3000 SO-DIMM DDR3L USB3.0 WiFi/BT PC
£254.51
saving £8.33
Processor Model: N3000
Type: PC barebone
Case Style: Ultra small form factor
Display: no
Optical Storage: None
Brand: Gigabyte
Price Range Ex VAT: 50 - 100
