Gigabyte BRIX Intel Celeron N3000 SO-DIMM DDR3L USB3.0
Quicklinx: BRRTWS00 Mfr#: GB-BACE-3000
Processor Type: Celeron
Operating System: No operating system
Installed Memory: 0MB
Hard Drive Capacity: 0GB
Storage Type: No HDD
  • Celeron
Hurry, only 2 left in stock!
£109.07 ex VAT
£130.88 inc VAT
Challenging the essence of how you define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a stylish design based high polish surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact, versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough to sit in the palm of your hand.
  • Intel Celeron processor
    Based on the Silvermot micro-architecture which utilizes the 14nm process technology, these SoC feature significant improvements in computational power, energy efficiency, enhanced graphical and media performance making the BRIX ideal for thin clients, retail transactional clients, and digital signage.
  • Advanced features for power users
    The Brix is engineered to take full advantage of what the hardware and its UEFI BIOS are capable of. And therefore, it's designed to deliver the most intuitive and integrated operating systems in the world.
  • VESA support
    The BRIX is packed with wall mount adapter whether undergo rigorous testing for safety and reliability. The BRIX also bundled with a VESA bracket, it can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This offers a simple and elegant way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
Gigabyte BRIX GB-BACE-3000 (rev. 1.0) - Ultra Compact PC Kit - Celeron N3000 1.04 GHz - 0 MB
PC barebone - Ultra Compact PC Kit
1 x Intel Celeron N3000 / 1.04 GHz (2.08 GHz) (Dual-Core)
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
0 MB (installed) / 8 GB (max) - DDR3L SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Graphics Controller
Intel HD Graphics
Audio Output
Stereo
GigE
AC 120/230 V
OS Provided
No operating system
10.76 cm x 11.44 cm x 5.61 cm
PC barebone
Product Form Factor
Processor / Chipset
CPU
Max Turbo Speed
2.08 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
0 MB / 8 GB (max)
DDR3L SDRAM
SO-DIMM 204-pin
Slots
1 (Total) / 1 (empty)
Hard Drive
No HDD
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
1
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel HD Graphics
Video Interfaces
VGA, HDMI
Max Monitors Supported
2
Audio Output
Sound Output Mode
Stereo
Ethernet Controller
Realtek RTL8111H
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x SO-DIMM 204-pin , 1 M.2 Card
4 x USB 3.0 , 1 x HDMI , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x headphones - mini-jack , 1 x microphone - mini-jack
VESA wallmount adapter
UEFI BIOS
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Power adapter
Nominal Voltage
AC 120/230 V
Operating System / Software
OS Provided
No operating system
10.76 cm
11.44 cm
5.61 cm
35 °C
Gigabyte BRIX Intel Celeron N3000 SO-DIMM DDR3L USB3.0 Bundle deal on Gigabyte BRIX Intel Celeron N3000 SO-DIMM DDR3L USB3.0
£295.53
saving £8.33
£208.83
Processor Model: N3000
Type: PC barebone
Case Style: Ultra small form factor
Display: no
Optical Storage: None
Brand: Gigabyte
Price Range Ex VAT: 100 - 150
