Redefining the Desktop PC
Challenging the essence of how we define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a brushed aluminum surface chassis design. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. With a broad choice of processors covering the entire performance spectrum, the BRIX sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit.
Intel Thunderbolt 3 Controller, Opening a World of New Possibilities
The new Thunderbolt 3 protocol, which is available over a USB Type-C connector on the back panel of the GIGABYTE BRIX T models, brings an unprecedented single-wire bandwidth of up to 40 Gb/s -- twice more than the previous generation of Thunderbolt! This incredible increase in bandwidth is also accompanied with support for different protocols such as DisplayPort 1.2, which is able to drive a 4K resolution display at 60 FPS, and USB 3.1, also backwards compatible with USB 3.0 and USB 2.0, opening up a world of new possibilities. Additionally, Thunderbolt 3 over USB Type-C has the ability to daisy-chain up to 6 devices, helping you to declutter your desktop and have a true one-cable solution.
Dual Display
With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect choice as a high productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications.
Extreme Intel USB 3.1 Controller
GIGABYTE introduces the fast 10Gb/s USB3.1 Gen2 protocol to its BRIX units over the new reversible USB Type-C port. Powered by the Intel USB 3.1 controller which utilizes 4 PCIe Gen 3 lanes, the GIGABYTE BRIX Type-C port is presented with a wide and uncompromised bandwidth to reach the limits of the USB 3.1 protocol and make back-ups or file transfers a quick operation, Additionally, USB 3.1 is backwards compatible with USB 2.0 and 3.0 making the GIGABYTE BRIX a versatile and widely compatible small form factor PC over a wider range of devices.
Connecting the Future - USB Type-C: The World's Next Universal Connector
Reversible Dual USB Type-C with USB 3.1
The USB Type-C is a new reversible connector that is loaded with useful features such as USB 3.1 support for 10 Gb/s transfer speed. Powered by the Intel USB 3.1 controller, this little port provides the best USB Type-C experience possible.
USB 3.0 and Network Connectivity
GIGABYTE BRIX also includes a M.2 module offering IEEE 802.11ac Wi-Fi and the latest Bluetooth 4.2, providing connectivity for low power Bluetooth devices and peripherals, as well as allowing users to easily connect mobile devices.
Flexible Compact PC Kit
The BRIX is sold as a DIY PC kit, shipping with a NGFF M.2 Wi-Fi module pre-installed, plus a power adapter and cable conforming to local standards. Requiring only system memory and M.2 SSD, the BRIX gives users the flexibility to independently choose integrated storage and system memory size, without the trouble of sourcing components that are not widely available on the retail market.
VESA Support
Bundled with a VESA bracket, the BRIX can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This makes it simple and effective way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
Redefining the desktop PC
Challenging the essence of how a desktop PC is defined, Gigabyte engineers have developed an ultra compact PC with a brushed aluminum surface chassis design. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. The BRIX sets a different standard for desktop miniaturization that makes it perfect as a discreet HTPC / multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. -
Dual display
With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect choice as a high-productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications. -
Extreme USB 3.1 controller
Gigabyte introduces the fast 10 Gb/s USB 3.1 Gen2 protocol to its BRIX units over the advanced reversible USB Type-C port. Additionally, USB 3.1 is backwards compatible with USB 2.0 and 3.0 making the Gigabyte BRIX a versatile and widely compatible small form factor PC. -
The USB Type-C is an alternative reversible connector that is loaded with useful features such as USB 3.1 support for 10 Gb/s transfer speed. Powered by the USB 3.1 controller, this little port provides the amazing USB Type-C experience. -
VESA support
The BRIX can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This makes it simple and effective way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
- Gigabyte BRIX s GB-BSi7HT-6500 (rev. 1.0) - Ultra Compact PC Kit - Core i7 6500U 2.5 GHz - 0 GB - no HDD
- PC barebone - Ultra Compact PC Kit
- Processor
- 1 x Intel Core i7 (6th Gen) 6500U / 2.5 GHz (, up to 3.1 GHz, (Dual-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 4 MB
- Cache Per Processor
- 4 MB
- RAM
- 0 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Card Reader
- Graphics Controller
- Intel HD Graphics 520
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V
- OS Provided
- No operating system
- 11.26 cm x 11.94 cm x 4.68 cm
- PC barebone
- Product Form Factor
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6500U
- Clock Speed
- 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 4 MB
- 4 MB
RAM
- Installed Size
- 0 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 2 (empty)
Hard Drive
- No HDD
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- Ethernet Controller
- Intel I219-V
- Data Link Protocol
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 2 M.2 Card , 2 (total) / 2 (free) x SO-DIMM 260-pin
- 4 x USB 3.0 (2 in front) , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones - mini-jack (1 in front) , 1 x microphone - mini-jack (1 in front) , 1 x USB-C 3.1
- Included Accessories
- VESA wallmount adapter
- Theft/Intrusion Protection
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Power adapter
- Voltage Required
- AC 120/230 V
Operating System / Software
- OS Provided
- 11.26 cm
- 11.94 cm
- 4.68 cm
- 0 °C
- 35 °C
