Gigabyte BRIX GB-BSi5-6200 (rev. 1.0) Core i5 6200U 2.3 GHz
Quicklinx: BW8JWS00 Mfr#: GB-BSi5-6200
  • Core i5
This ultra-compact PC with a stylish glass surface chassis design is ideal for various computing applications at home or in the office. The BRIX sets a higher standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect solution as a high-productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications.
  • Redefining the desktop PC
    This ultra-compact PC with a stylish glass surface chassis design is ideal for various computing applications at home or in the office, it expounds sheer simplicity and convenience. The BRIX sets a higher standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit.
  • Dual display
Gigabyte BRIX GB-BSi5-6200 (rev. 1.0) - Ultra Compact PC Kit - Core i5 6200U 2.3 GHz - 0 GB - no HDD
PC barebone - Ultra Compact PC Kit
1 x Intel Core i5 (6th Gen) 6200U / 2.3 GHz (, up to 2.8 GHz, (Dual-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
0 GB (installed) / 16 GB (max) - DDR3L SDRAM
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 520
Audio Output
Stereo
GigE
AC 120/230 V
OS Provided
No operating system
11.26 cm x 11.94 cm x 3.44 cm
PC barebone
Product Form Factor
Processor / Chipset
CPU
Clock Speed
2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
0 GB / 16 GB (max)
DDR3L SDRAM
SO-DIMM 204-pin
Slots
2 (Total) / 2 (empty)
Hard Drive
No HDD
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Max Monitors Supported
2
Audio Output
Sound Output Mode
Stereo
Slots
2 M.2 Card , 2 (total) / 2 (free) x SO-DIMM 204-pin
4 x USB 3.0 (2 front, 2 rear) , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front)
VESA wallmount adapter
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Power adapter
AC 120/230 V
Operating System / Software
OS Provided
No operating system
11.26 cm
11.94 cm
3.44 cm
35 °C
