This ultra-compact PC with a stylish glass surface chassis design is ideal for various computing applications at home or in the office. The BRIX sets a higher standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect solution as a high-productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications.
Redefining the desktop PC
This ultra-compact PC with a stylish glass surface chassis design is ideal for various computing applications at home or in the office, it expounds sheer simplicity and convenience. The BRIX sets a higher standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. -
Dual display
- Gigabyte BRIX GB-BSi5-6200 (rev. 1.0) - Ultra Compact PC Kit - Core i5 6200U 2.3 GHz - 0 GB - no HDD
- PC barebone - Ultra Compact PC Kit
- Processor
- 1 x Intel Core i5 (6th Gen) 6200U / 2.3 GHz (, up to 2.8 GHz, (Dual-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 0 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 520
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V
- OS Provided
- No operating system
- 11.26 cm x 11.94 cm x 3.44 cm
- PC barebone
- Product Form Factor
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U
- Clock Speed
- 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 0 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
Hard Drive
- No HDD
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- Data Link Protocol
- Slots
- 2 M.2 Card , 2 (total) / 2 (free) x SO-DIMM 204-pin
- 4 x USB 3.0 (2 front, 2 rear) , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front)
- Included Accessories
- VESA wallmount adapter
- Theft/Intrusion Protection
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Power adapter
- Voltage Required
- AC 120/230 V
Operating System / Software
- OS Provided
- 11.26 cm
- 11.94 cm
- 3.44 cm
- 0 °C
- 35 °C
