Gigabyte BRIX GB-BSi3HA-6100 (rev. 1.0) Intel Core i3-6100U 2.3 GHz - 0 MB - 0 GB
Quicklinx: C5DGWS00 Mfr#: GB-BSi3HA-6100
  • Core i3
The Power of Intel® Core™ / Intel® 6th Gen Core™ Processors
The 6th Generation of Intel® Core i3 processors are perfect for those on a budget and only need to do lighter tasks such as web surfing or word processing. Think of this as a cost effective solution for those that need a PC for basic tasks. Intel CPUs have a number of built-in features to ensure top of the line performance. When using processor-intensive applications integrated memory controller provides a direct connection between the memory and the processor for fast data processing.
Intel® HD 520 Graphics
Intel® HD 520 Graphics deliver up to 1.34x more pixel-pushing performance than the previous generation. This directly results in smoother and more responsive video playback and game play. With the Intel® HD 520 Graphics, you now have the power needed to edit HD videos and play games at ultra-high resolutions and silky-smooth frame rates.
Fast USB 3.1 Solution
The latest USB 3.1 offers a staggering 10Gb/s transfer speed, 2x faster than USB 3.0 and backward compatibility with existing USB devices.
Connecting the Future - USB Type-C™: The World's Next Universal Connector
Reversible Dual USB Type-C™ with USB 3.1
The USB Type-C™ is a new reversible connector that is loaded with useful features such as USB 3.1 support for 10 Gb/s transfer speed.
USB 3.0 and Network Connectivity
GIGABYTE BRIX™ also includes a M.2 module offering IEEE 802.11ac Wi-Fi and the latest Bluetooth 4.2, providing connectivity for low power Bluetooth devices and peripherals, as well as allowing users to easily connect mobile devices.
SuperSpeed 4K HD Entertainment
Native 4K HD Decode Support
The GIGABYTE BRIX™ now support a native resolution of 4K, bringing unrivalled visual clarity and stunning realism to owners of 4K HDTV or PC monitors. This also opens up new possibilities for those in the digital signage interested in the small footprint of the GIGABYTE BRIX™, and those in need of a 4K display solution capable of delivering an ultra-realistic, high definition visual experience.
Multi-display productivity with HDMI & DisplayPort++
BRIX supports up to three independent displays through HDMI and a DisplayPort ++ without the need for an additional graphics card. Support for three display is only possible with daisy-chain connections through Display Port++.
VESA Support
Bundled with a VESA bracket, the GIGABYTE BRIX™ can easily be mounted behind a monitor or HDTV, offering a simple and effective way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
2.5" Hard Drive Support
Utilizing SATA III 6 Gb/s high speed data transfer technology, the GIGABYTE BRIXs supports the installation of one 2.5" SATA 6Gbps HDD or Solid State Drive (SSD) and one M.2 2280 SSD module. This allows for optimized storage configurations which combine fast M.2 performance with larger capacity 2.5" hard drive.
  • Reversible dual USB Type-C with USB 3.1
    The USB Type-C is a reversible connector that is loaded with useful features such as USB 3.1 support for 10 Gb/s transfer speed.
  • USB 3.0 and network connectivity
    GIGABYTE BRIX also includes a M.2 module offering IEEE 802.11ac Wi-Fi and the latest Bluetooth 4.2, providing connectivity for low power Bluetooth devices and peripherals, as well as allowing users to easily connect mobile devices.
  • Native 4K HD decode support
    The GIGABYTE BRIX now support a native resolution of 4K, bringing unrivaled visual clarity and stunning realism to owners of 4K HDTV or PC monitors. This also opens up possibilities for those in the digital signage interested in the small footprint of the GIGABYTE BRIX, and those in need of a 4K display solution capable of delivering an ultra-realistic, high definition visual experience.
  • Multi-display productivity with HDMI & DisplayPort++
Gigabyte BRIX s GB-BSi3HA-6100 (rev. 1.0) - Ultra Compact PC Kit - Core i3 6100U 2.3 GHz - 0 MB
PC barebone - Ultra Compact PC Kit
1 x Intel Core i3 (6th Gen) 6100U / 2.3 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
0 MB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 520
Audio Output
Stereo
GigE
AC 120/230 V
OS Provided
No operating system
11.26 cm x 11.94 cm x 4.68 cm
PC barebone
Product Form Factor
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
0 MB / 32 GB (max)
DDR4 SDRAM
SO-DIMM 260-pin
Slots
2 (Total) / 2 (empty)
Hard Drive
No HDD
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
Sound Output Mode
Stereo
Ethernet Controller
Intel I219-LM
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 M.2 Card , 2 (total) / 2 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2280
2 x USB 3.0 , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone - mini-jack (1 in front) , 1 x USB 3.1 (1 in front) , 1 x USB-C 3.1 (1 in front)
VESA wallmount adapter
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Power adapter
Nominal Voltage
AC 120/230 V
Operating System / Software
OS Provided
No operating system
11.26 cm
11.94 cm
4.68 cm
35 °C
