Gigabyte BRIX GB-BSi3H-6100 (rev. 1.0) Core i3 6100U 2.3 GHz
Quicklinx: BW8RWS00 Mfr#: GB-BSi3H-6100
  • Core i3
This is an ultra-compact PC with a stylish glass surface chassis design. Ideal for various computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. The BRIX sets a higher standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect solution as a high productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications.
  • Redefining the desktop PC
  • Dual display
  • 2.5” SATA hard drive support
    Utilizing SATA III high speed data transfer technology, the BRIX supports the installation of one 2.5” SATA hard drive and one M.2 SSD module. This allows for optimized storage configurations which combine fast SSD performance with larger capacity hard drives.
Gigabyte BRIX s GB-BSi3H-6100 (rev. 1.0) - Ultra Compact PC Kit - Core i3 6100U 2.3 GHz - 0 GB - no HDD
PC barebone - Ultra Compact PC Kit
1 x Intel Core i3 (6th Gen) 6100U / 2.3 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
0 GB (installed) / 16 GB (max) - DDR3L SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 520
Audio Output
Stereo
GigE
AC 120/230 V
OS Provided
No operating system
11.26 cm x 11.94 cm x 4.68 cm
PC barebone
Product Form Factor
Processor / Chipset
CPU
Clock Speed
2.3 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
0 GB / 16 GB (max)
DDR3L SDRAM
SO-DIMM 204-pin
Slots
2 (Total) / 2 (empty)
Hard Drive
No HDD
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Max Monitors Supported
2
Audio Output
Sound Output Mode
Stereo
Ethernet Controller
Intel I219-V
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
2 M.2 Card , 2 (total) / 2 (free) x SO-DIMM 204-pin
4 x USB 3.0 (2 front, 2 rear) , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front)
VESA wallmount adapter
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Power adapter
AC 120/230 V
Operating System / Software
OS Provided
No operating system
11.26 cm
11.94 cm
4.68 cm
35 °C
