This is an ultra-compact PC with a stylish glass surface chassis design. Ideal for various computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. The BRIX sets a higher standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect solution as a high productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications.
Redefining the desktop PC
This is an ultra-compact PC with a stylish glass surface chassis design. Ideal for various computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. The BRIX sets a higher standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. -
Dual display
With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect solution as a high productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications. -
2.5” SATA hard drive support
Utilizing SATA III high speed data transfer technology, the BRIX supports the installation of one 2.5” SATA hard drive and one M.2 SSD module. This allows for optimized storage configurations which combine fast SSD performance with larger capacity hard drives.
- Gigabyte BRIX s GB-BSi3H-6100 (rev. 1.0) - Ultra Compact PC Kit - Core i3 6100U 2.3 GHz - 0 GB - no HDD
- PC barebone - Ultra Compact PC Kit
- Processor
- 1 x Intel Core i3 (6th Gen) 6100U / 2.3 GHz (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 0 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 520
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V
- OS Provided
- No operating system
- 11.26 cm x 11.94 cm x 4.68 cm
- PC barebone
- Product Form Factor
Processor / Chipset
- CPU
- Intel Core i3 (6th Gen) 6100U
- Clock Speed
- 2.3 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 0 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
Hard Drive
- No HDD
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- Ethernet Controller
- Intel I219-V
- Data Link Protocol
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 2 M.2 Card , 2 (total) / 2 (free) x SO-DIMM 204-pin
- 4 x USB 3.0 (2 front, 2 rear) , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front)
- Included Accessories
- VESA wallmount adapter
- Theft/Intrusion Protection
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Power adapter
- Voltage Required
- AC 120/230 V
Operating System / Software
- OS Provided
- 11.26 cm
- 11.94 cm
- 4.68 cm
- 0 °C
- 35 °C
