Challenging the essence of how a desktop PC is defined, GIGABYTE engineers have developed an ultra-compact PC with a brushed aluminum surface chassis design. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience.
The latest USB 3.1 offers a staggering 10 Gb/s transfer speed, 2x faster than USB 3.0 and backward compatibility with existing USB devices.
GIGABYTE ensures users won't be limited by the standards or connections on the BRIX, by including HDMI 2.0 and support for HDCP 2.2 users can rest assured that their device will be able to display content to its full potential. The BRIX supports native resolutions of 4K at 60Hz, presenting unrivaled visual clarity and stunning realism to owners of UHD displays.
BRIX supports up to three independent displays through HDMI 2.0 and a DisplayPort ++ without the need for an additional graphics card. Support for three displays is only possible with daisy-chain connections through Display Port++.
Perfect fit for any space
Challenging the essence of how a desktop PC is defined, GIGABYTE engineers have developed an ultra-compact PC with a brushed aluminum surface chassis design. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. -
Fast USB 3.1 solution
The latest USB 3.1 offers a staggering 10 Gb/s transfer speed, 2x faster than USB 3.0 and backward compatibility with existing USB devices. -
SuperSpeed 4K HD entertainment
GIGABYTE ensures users won't be limited by the standards or connections on the BRIX, by including HDMI 2.0 and support for HDCP 2.2 users can rest assured that their device will be able to display content to its full potential. The BRIX supports native resolutions of 4K at 60Hz, presenting unrivaled visual clarity and stunning realism to owners of UHD displays. -
Multi-display productivity with HDMI 2.0 and DisplayPort++
- Gigabyte BRIX s GB-BKi5HA-7200 (rev. 1.0) - Ultra Compact PC Kit - Core i5 7200U 2.5 GHz - 0 GB - no HDD
- PC barebone - Ultra Compact PC Kit
- Processor
- 1 x Intel Core i5 (7th Gen) 7200U / 2.5 GHz (, up to 3.1 GHz, (Dual-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- RAM
- 0 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 620
- Audio Output
- Stereo
- Networking
- 1GbE
- Power
- AC 120/230 V
- OS Provided
- No operating system
- 11.26 cm x 11.94 cm x 4.68 cm
- PC barebone
- Product Form Factor
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U
- Clock Speed
- 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 0 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 2 (empty)
Hard Drive
- No HDD
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 M.2 Card - 2230 , 2 (total) / 2 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2280
- 2 x USB 3.0 , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone - mini-jack (1 in front) , 1 x USB 3.1 (1 in front) , 1 x USB-C 3.1 (1 in front)
- Included Accessories
- VESA wallmount adapter
- Theft/Intrusion Protection
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Power adapter
- Voltage Required
- AC 120/230 V
Operating System / Software
- OS Provided
- 11.26 cm
- 11.94 cm
- 4.68 cm
- 0 °C
- 35 °C
