Gigabyte Brix BXBT-1900 Ultra Compact PC Kit - Intel Celeron J1900 2GHz
Quicklinx: B917WS00 Mfr#: GB-BXBT-1900
  • Bluetooth 4.0
  • IEEE 802.11n
  • Celeron
£102.54 ex VAT
£123.04 inc VAT
Redefining the Desktop PC
Challenging the essence of how we define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a stylish design based high polish surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC / multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact,versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough (56mm x 107mm x 114mm) to sit in the palm of your hand.
• Features 22nm Intel® Celeron J1900 to deliver to the most intuitive and integrated operating systems in the world
• Supports 2.5" thickness 7.0/9.5mm Hard Drives (1 x 3Gbps)
• Ultra compact PC design – 0.69L(56.1x 107.6 x 114.4mm)
• 1x SO-DIMM DDR3L 1.35V Slots (1333 MHz)
• Preinstall IEEE 802.11 b/g/n Wi-Fi / Bluetooth 4.0 Mini-PCIe card
• Supports dual displays via a VGA and a HDMI port
• Gigabit LAN
• Audio jack (Headphone/MIC)
• VESA mounting bracket (75 x 75mm + 100 x 100mm)
Based on the Silvermot micro-architecture, utilizing the 22nm process technology. The SoCs feature significant improvements in computational power, energy efficiency, enhanced graphical and media performance making the BRIX ideal for thin clients, retail transactional clients, and digital signage.
Advanced Features For Power Users
The Brix is engineered to take full advantage of what the hardware and its UEFI BIOS are capable of. And therefore, it’s designed to deliver the most intuitive and integrated operating systems in the world.
Trouble-Free Setup
The BRIX is packed with wall mount adapter whether undergo rigorous testing for safety and reliability. The BRIX also bundled with a VESA bracket, it can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This offers a simple and elegant way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
  • Redefining the desktop PC
    Challenging the essence of how define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a stylish design based around an anthracite aluminum frame and glass surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, sets a standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact, versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough to sit in the palm of your hand.
  • Intel Celeron J1900
    Based on the silver mot micro-architecture, utilizing the 22 nm process technology, the SoCs feature significant improvements in computational power, energy efficiency, enhanced graphical and media performance making the BRIX ideal for thin clients, retail transactional clients, and digital signage.
  • Advanced features for power users
    The Brix is engineered to take full advantage of what the hardware and its UEFI BIOS are capable of. And therefore, it's designed to deliver the most intuitive and integrated operating systems in the world.
  • Trouble-free setup
Gigabyte BRIX GB-BXBT-1900 (rev. 1.0) - mini PC - Celeron J1900 2 GHz - 0 GB
PC barebone - mini PC
1 x Intel Celeron J1900 / 2 GHz (2.42 GHz) (Quad-Core)
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
0 GB (installed) / 8 GB (max) DDR3L SDRAM
Storage Controller
SATA
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics
GigE, 802.11b/g/n, Bluetooth 4.0
AC 120/230 V
OS Provided
No operating system
10.76 cm x 11.44 cm x 5.61 cm
PC barebone
Product Form Factor
Mini PC
Processor / Chipset
CPU
Max Turbo Speed
2.42 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
0 GB / 8 GB (max)
DDR3L SDRAM
SO-DIMM 204-pin
Slots
1 (Total) / 1 (empty)
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Channel Qty
1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Intel HD Graphics
Video Interfaces
VGA, HDMI
Ethernet Controller
Realtek RTL8111G
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x PCIe Half Mini Card , 1 (total) / 1 (free) x SO-DIMM 204-pin
1 x USB 3.0 (1 in front) , 1 x HDMI , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x audio line-in/microphone - mini-jack
VESA wallmount adapter
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Power adapter
Nominal Voltage
AC 120/230 V
Operating System / Software
OS Provided
No operating system
10.76 cm
11.44 cm
5.61 cm
Gigabyte Brix BXBT-1900 Ultra Compact PC Kit - Intel Celeron J1900 2GHz Bundle deal on Gigabyte Brix BXBT-1900 Ultra Compact PC Kit - Intel Celeron J1900 2GHz
£201.71
Brand: Gigabyte
Price Range Ex VAT: 100 - 150
