Your basket is empty
Gigabyte ATX E5-1600 DIMM 1066MHz
Quicklinx: B9L9WS00 Mfr#: GA-6PXSV1
£231.31 ex VAT
£277.57 inc VAT
The 6PXSV series being the only ATX boards supporting the Intel Xeon E5-1600 V2 & E5-2600 V2 processor, ECC memory and boasting the C604 chipset, they will be the perfect solution for professional users and prosumers wishing to build compact yet highly productive workstations that will boost their workflow.
Deployable through a simple BIOS update, the support of Intel Xeon processor E5-1600 V2 & 2600 V2 product families delivers the benefits of the 22nm tri-gate process technology to the high end server industry. Those benefits include, among others, higher frequencies, higher core counts and larger last-level caches, but especially a much more varied mix of core/frequencies with notably the introduction of a dual socket workstation segment. This die shrink also allows for overall energy efficiency increase, with up to 30% average decrease in idle power consumption.
Gigabyte GA-6PXSV1 - 1.0 - motherboard - ATX - LGA2011 Socket - C604
Motherboard - ATX
Chipset Type
Intel C604
Processor Socket
1 x LGA2011 Socket
Compatible Processors
Xeon E5-1600 series, Xeon E5-2600 series, Xeon E5-2600 v2 series, Xeon E5-1600 v2 series
Max RAM Size
256 GB
RAM Supported
8 DIMM slots - DDR3, non-ECC, ECC, registered, unbuffered
Storage Ports
4 x SAS (RAID), 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
1 x FireWire + 6 x USB 2.0 + (4 x USB 3.0 + 1 x FireWire via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel C604
Processor Socket
LGA2011 Socket
Max Processors Qty
1
Supported RAM
Max Size
256 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Registered, unbuffered
Quad channel memory architecture
Details
256 GB - registered , 64 GB - unbuffered
Audio
Audio Codec
Realtek ALC892
High Definition Audio, Dolby Home Theater
LAN
Network Controller
Intel 82579LM
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 8 x DIMM 240-pin (1.5 V/ 1.35 V) , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x8 mode) , 1 x PCIe 3.0 x8 , 1 x PCIe 2.0 x4 , 1 x PCI
Storage Interfaces
SAS - 4 devices - RAID 0 / RAID 1 / RAID 10 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
6 x USB 2.0 , 2 x serial , 1 x LAN (Gigabit Ethernet) , 1 x FireWire , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
4 x USB 3.0 - header , 1 x FireWire - header , 1 x SPDIF - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
Hardware Features
Square ILM
30.5 cm
24.4 cm
Brand: Gigabyte
Price Range Ex VAT: 150 - 300
