Product
Brand
Gigabyte ATX E5-1600/2600/V2 2xGbE
Quicklinx: B9LFWS00 Mfr#: GA-6PXSVL
Deployable through a simple BIOS update, the support of Intel Xeon processor E5-1600 V2 & 2600 V2 product families delivers the benefits of the 22nm tri-gate process technology to the high end server industry. Those benefits include, among others, higher frequencies, higher core counts and larger last-level caches, but especially a much more varied mix of core/frequencies with notably the introduction of a dual socket workstation segment. This die shrink also allows for overall energy efficiency increase, with up to 30% average decrease in idle power consumption.
Gigabyte GA-6PXSVL - 1.0 - motherboard - ATX - LGA2011 Socket - C602
Motherboard - ATX
Chipset Type
Intel C602
Processor Socket
1 x LGA2011 Socket
Compatible Processors
Xeon E5-1600 series, Xeon E5-2600 series, Xeon E5-2600 v2 series, Xeon E5-1600 v2 series
Max RAM Size
256 GB
RAM Supported
8 DIMM slots - DDR3, non-ECC, ECC, registered, unbuffered
Storage Ports
10 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 3.0 + 3 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Graphics
ASPEED AST2400
LAN
2 x Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel C602
Processor Socket
LGA2011 Socket
Max Processors Qty
1
Supported RAM
Max Size
256 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Registered, unbuffered
Single rank, dual rank, quad channel memory architecture, quad rank
Details
256 GB - registered , 64 GB - unbuffered
Graphics
Graphics Controller
ASPEED AST2400
LAN
Network Controller
2 x Intel 82574L
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 240-pin (1.5 V/ 1.35 V) , 2 x PCIe 3.0 x16
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9230: SATA-600 -connectors: 8 x 7pin Serial ATA - 8 devices - RAID 0 / RAID 1 / RAID 10 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x PS/2 keyboard / mouse , 2 x USB 3.0 , 4 x USB 2.0
Internal Interfaces
2 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x USB 2.0 - Type A , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
Hardware Features
Clear CMOS Button, narrow ILM
I/O back plate
2 x Serial ATA cable
30.5 cm
24.4 cm
