Still based on the 22 nm tri-gate lithography, this generation of Xeon processor is built on Intel's microarchitecture and brings up to 15% computing power improvements and increased L3 cache across the line. In addition, this generation will also bring to the Xeon E3 family the support of 1600 MHz ECC memory, Intel Trusted Execution and Virtualization technologies, as well as AVX 2.0 and TSX instructions. Last but not least, the Xeon E3-1200 V3 processor will include the latest Intel integrated graphics, which will bring the support of OGL3.2+, DirectX 11.1, and higher frequencies.
Intel Xeon processor E3-1200 V3 product family
Still based on the 22 nm tri-gate lithography, this generation of Xeon processor is built on Intel's microarchitecture and brings up to 15% computing power improvements and increased L3 cache across the line. In addition, this generation will also bring to the Xeon E3 family the support of 1600 MHz ECC memory, Intel Trusted Execution and Virtualization technologies, as well as AVX 2.0 and TSX instructions. Last but not least, the Xeon E3-1200 V3 processor will include the latest Intel integrated graphics, which will bring the support of OGL3.2+, DirectX 11.1, and higher frequencies. -
10GbE LAN
With virtualized environments getting always more popular and asking for always more resources from the networking side of any system, the GA-6LXGL is ready for high-performance virtual applications thanks to its 10GbE SFP+ controller. Capable of load-balancing, FCoE support, and low latency transfers, this solution allows a simplification of a network's topology while boosting its overall performance. -
Generation of Dual GbE LAN Controller
With the 3rd iteration of the Intel Xeon processor E3-1200 family also came a generation of dual gigabit LAN controllers. Equipped with an Intel I210 controller, this board is now capable of advanced features such as error correction packet buffers, enhanced management with OS2BMC, MCTP, NC-SI, SMBus, and generally improved transfer performance as well as reduced power consumption. -
Support of PCIe Generation 3.0
With the support of the PCI Express Gen. 3.0 technology directly on the CPU, the GA-6LXGL is fully configured to provide users with dramatically reduced latency and improved data bandwidth to get the most out of its expansion accessories.
- Gigabyte GA-6LXGL - 1.0 - motherboard - ATX - LGA1150 Socket - C224
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel C224
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Core i3, Xeon E3-1200 v3 series
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, ECC, unbuffered
- Storage Ports
- 4 x SATA-600 (RAID), 2 x SATA-300 (RAID)
- USB / FireWire Ports
- 4 x USB 3.0 + 3 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
- Graphics
- ASPEED AST2400-VB
- LAN
- 10 Gigabit Ethernet, 2 x Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel C224
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz
- Supported RAM Integrity Check
- ECC
- Registered or Buffered
- Unbuffered
- Single rank, dual rank
Graphics
- Graphics Controller
- ASPEED AST2400-VB
LAN
- Network Controller
- Intel 82599 / I210
- Network Interfaces
- Expansion Slots
- 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x1 , 3 x PCI , 1 x CPU
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- 4 x USB 3.0 , 2 x USB 2.0 , 1 x VGA , 1 x PS/2 keyboard / mouse , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x LAN (10Gigabit Ethernet)
- Internal Interfaces
- 2 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x USB 2.0 - Type A , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- 30.5 cm
- 24.4 cm
