Product
Brand
Gigabyte ATX E3-1200 DIMM Dual Gbe
Quicklinx: B9LJWS00 Mfr#: GA-6UASL3
By combining a microATX form factor with the Intel Xeon processors, this board is a convenient and versatile solution for SMBs to build affordable yet high performing tower servers.
With the support of the PCI Express generation 3.0 technology directly on the CPU, the GA-6UASL3 is fully configured to provide users with dramatically reduced latency and improved data bandwidth to get the most out of its expansion accessories.
Gigabyte GA-6UASL3 - 1.0 - motherboard - micro ATX - LGA1155 Socket - C202
Motherboard - micro ATX
Chipset Type
Intel C202
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Xeon E3-1200 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, ECC
Storage Ports
6 x SATA-300 (RAID)
USB / FireWire Ports
7 x USB 2.0 + (3 x USB 2.0 via headers)
Graphics
XGI Volari Z9s
Dedicated Video Memory
64 MB
LAN
2 x Gigabit Ethernet
Chipset Type
Intel C202
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Xeon E3-1200 series
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
ECC
Dual channel memory architecture
Graphics
Graphics Controller
XGI Volari Z9s
64 MB
LAN
Network Controller
Intel 82574L
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin (1.5 V) , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x8 (x4 mode) , 1 x PCIe 2.0 x4 (x2 mode) , 1 x PCI
Storage Interfaces
SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
6 x USB 2.0 , 1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x serial
Internal Interfaces
1 x USB 2.0 - Type A , 3 x USB 2.0 - header , 1 x audio - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
24.4 cm
24.4 cm
