Gigabyte AORUS GeForce RTX 4080 SUPER MASTER 16GB OC Edition Graphics Card
Quicklinx: HVHGWS00 Mfr#: GV-N408SAORUS M-16GD
The GIGABYTE AORUS GeForce RTX 4080 SUPER MASTER 16G is a powerful video card designed for gamers and professionals. With 16 GB of GDDR6X memory and support for DirectX 12 Ultimate, it delivers high-quality graphics and smooth gameplay. The card's advanced cooling system, featuring Vapor chamber technology and a triple fan design, ensures it stays cool under pressure, enabling sustained performance. Innovative features like NVIDIA DLSS 3 and NVIDIA Reflex enhance gaming experiences, while RGB fusion allows for personalized lighting effects. Whether for gaming, content creation, or professional applications, this video card offers the power and flexibility to meet demanding computing needs.
  • Enhanced cooling
    The GIGABYTE AORUS GeForce RTX 4080 SUPER MASTER 16G features an advanced cooling system, including a 110 mm unique blade fan design, 3D Active Fan, and Vapor chamber cooling technology. This ensures optimal performance by maintaining lower temperatures even under heavy loads.
  • High performance
    Equipped with NVIDIA GeForce RTX 4080 SUPER graphics processor and 16 GB of GDDR6X SDRAM, this video card delivers high performance. The inclusion of 3rd gen Ray Tracing Cores and 4th gen Tensor Cores enables stunning visuals and AI-accelerated applications.
  • High-quality visuals
    Supporting DirectX 12 Ultimate and OpenGL 4.6, the card is capable of powering up to 4 monitors with a maximum resolution of 7680 x 4320. This allows for an immersive gaming experience and detailed graphic work.
  • Innovative features
    Features like NVIDIA DLSS 3, NVIDIA RTX Video Super Resolution, and NVIDIA Reflex enhance gaming experiences by improving frame rates, video quality, and responsiveness. The AORUS Bionic Shark fan technology and RGB fusion add to the aesthetic appeal while ensuring performance.
AORUS GeForce RTX 4080 SUPER MASTER 16G - OC Edition - graphics card - NVIDIA GeForce RTX 4080 SUPER - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4080 SUPER - up to
16 GB GDDR6X
Memory Speed
23 Gbps
Core Clock
2625 MHz
CUDA Cores
10240
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
DirectX 12 Ultimate, OpenGL 4.6
7.5 cm x 35.7 cm x 16.3 cm
4-year warranty with product registration
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Core Clock
2625 MHz
CUDA Cores
10240
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
3rd gen Ray Tracing Cores, 4th gen Tensor Cores, NVIDIA Ada Lovelace GPU technology, Triple Fan Design, NVIDIA DLSS 3, GIGABYTE WINDFORCE cooling design, AORUS Bionic Shark fan technology, LCD Edge View, Dual Bios, metal backplate, RGB fusion, Nvidia Studio, Nvidia Broadcast, NVIDIA Reflex, NVIDIA RTX Video Super Resolution, 110mm unique blade fan design, composite copper heat pipes, Vapor chamber cooling technology, GPU direct contact copper plates, 3D Active Fan, screen cooling, Dual ball Bearing Fans, PCB dust/moisture/corrosion coating, Ultra Durable VGA, Gigabyte Alternate Spinning
Size
16 GB
GDDR6X SDRAM
Memory Speed
23 Gbps
Bus Width
256-bit
Required Power Supply
850 W
Additional Requirements
16 pin PCI Express power connector
Anti-sag bracket, 16-pin to 3x 8-pin power adapter, AORUS metal sticker
Software Included
GeForce Game Ready Drivers, NVIDIA Studio drivers, Gigabyte Control Center
DisplayPort 1.4a
7.5 cm
35.7 cm
16.3 cm
Limited warranty - 3 years , Limited warranty - 4 years with product registration (within 30 days of purchase)
