Radeon™ RX 470 G1 Gaming 4G
Powered by Radeon ™ RX 470
WINDFORCE 2X with Blade Fan Design
Support up to UltraHD (4Kx2K)
16.8M Customizable Color RGB Lighting
Stylish Metal Back Plate
Core Clock
Boost: 1230 MHz
GIGABYTE G1 Gaming Series graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary AMD® Radeon ™ GPU architecture, G1 gaming graphics card brings you incredible gaming experience.
WINDFORCE 2X Cooling System
The WINDFORCE 2X cooling system features 3 pure copper composite heat-pipes, heat-pipe direct touch GPU, 90mm unique blade fan design, 3D active fan with LED indicators, stylish metal back plate, together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
WINDFORCE 2X Cooling System-Fans
90mm Unique Blade Fan Design
The airflow is spilt by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans
G1 Outlook
16.8M Customizable Color Lighting
With 16.8M customizable color options and numerous lighting effects, you could now choose the right scheme for your gaming rig through XTREME Engine utility.
The metal back plate offers rigidity and protection to the structure, while adding a sleek, clean look to the product.
Performance
One-click Super overclocking
With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment.
GPU Gauntlet™ Sorting
Forged with only the top-notch GPU, the Gigabyte G1 GAMING graphics cards guarantee higher overclocking capability in terms of excellent power switching, ensuring the highest performance without compromising system reliability.
Improved blade fan design
The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow. -
The semi-passive fans will remain off, when the GPU is under a set loading or temperature for low power gaming. The LED fan indicator on the top of the graphics card provides an instant display of the fan status. -
Composite heat pipes
The composite heat pipes combines both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces, which increases cooling capacity. -
3 heat pipes direct touch
The pure copper heat pipes are shaped to maximize the direct contact area to the GPU. -
Advanced GPU
Forged with the powerful GPU, the Gigabyte G1 graphics card delivers higher overclocking capability in terms of excellent power switching, ensuring the high performance without compromising system reliability. -
Smart power LED indicators
Be alert, when PCI-E voltage is unstable with the smart power LED indicator. -
Ultra-durable materials
Engineered with the high-grade chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan. -
Built for overclocking with 6+1 power phases
The 6+1 power phases on the card make the MOSFET working at a lower temperature and provide more stable voltage output.
- Gigabyte GV-RX470G1 GAMING-4GD - OC Edition - graphics card - Radeon RX 470 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon RX 470
- Memory
- 4 GB GDDR5
- Core Clock
- 1230 MHz
- Effective Memory Clock
- 6.6 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 5
- Interfaces Details
- HDMI , 3 x DisplayPort , DVI-D (dual link)
- API Supported
- DirectX 12, OpenGL 4.5
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon RX 470
- Core Clock
- 1230 MHz
- Process Technology
- 14 nm
- Max Resolution
- 7680 x 4320
- 5
- API Supported
- Ultra Durable VGA, GIGABYTE GPU Gauntlet Sorting, AMD Eyefinity Technology, GIGABYTE WindForce 2x, AMD CrossFireX Technology, GIGABYTE custom-designed 90 mm cooler
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.6 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- Software Included
- XTREME Engine Utility
