Radeon™ RX460 WINDFORCE OC 2G
Powered by Radeon RX460
Integrated with 2GB GDDR5 128bit memory
WINDFORCE 2X with Blade Fan Design
Support Full UHD HEVC Encode and Decode
Core Clock
1212 MHz
Improved blade fan design
The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow. -
3D active fan
The semi-passive fans will remain off, when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence, when the system is running light or idle. -
Ultra-durable graphics components
Engineered with the high-grade chokes and capacitors, the graphic card delivers outstanding performance and durable system lifespan. -
Built for overclocking with 4+1 power phases
The 4+1 power phases on the card make the MOSFET working at a lower temperature and provide more stable voltage output.
- Gigabyte GV-RX460WF2OC-2GD - OC Edition - graphics card - Radeon RX 460 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x8
- Graphics Engine
- AMD Radeon RX 460
- Memory
- 2 GB GDDR5
- Core Clock
- 1212 MHz
- Effective Memory Clock
- 7 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 3
- Interfaces Details
- HDMI , DisplayPort , DVI-D (dual link)
- API Supported
- DirectX 12, OpenGL 4.5
- 3.7 cm x 19.1 cm x 11.1 cm
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon RX 460
- Core Clock
- 1212 MHz
- Process Technology
- 14 nm
- Max Resolution
- 7680 x 4320 at 60 Hz
- 3
- API Supported
- Ultra Durable VGA, AMD Eyefinity Technology, GIGABYTE WindForce 2x, Dual Fan Design, AMD CrossFireX Technology, 4+1 Phase Power Design
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 350 W
- Software Included
- XTREME Engine Utility
- 3.7 cm
- 19.1 cm
- 11.1 cm
