Gigabyte AMD Radeon RX 550 D5 2GB PCIe3.0 Graphics Card
Quicklinx: CVNWWS00 Mfr#: GV-RX550D5-2GD
Graphics Processor Manufacturer: AMD
Graphics Processor: AMD Radeon RX 550
Interface: PCI Express 3.0 x16
Memory Size: 2GB, 2GB
£106.68 ex VAT
£128.01 inc VAT
  • Unique blade fan design
    The airflow is split by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow.
  • 3D active fan
    The semi-passive fans will remain off when the GPU is under a set loading or temperature for lower power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle.
  • Durable components
    Engineered with high-quality chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan.
  • Smooth and crisp visual
    Equipped with extensive connectivity ports, the card can deliver beautiful and smooth video playback.
Gigabyte Radeon RX 550 D5 2G - graphics card - Radeon RX 550 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 550
2 GB GDDR5
Core Clock
1195 MHz
Effective Memory Clock
7 GHz
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Resolution Details
DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported
3
DVI-D (dual link) , HDMI , DisplayPort
API Supported
DirectX 12, OpenGL 4.5
2.92 cm x 17 cm x 11.46 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 550
Core Clock
1195 MHz
Process Technology
14 nm
Max Resolution
7680 x 4320
3
API Supported
Ultra Durable 2, AMD Eyefinity Technology, GIGABYTE Super Overclock, solid state capacitors, FreeSync Technology, AMD XConnect Technology, 90mm Unique blade fan design, AORUS Graphics Engine
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
7 GHz
Bus Width
128-bit
Required Power Supply
400 W
DisplayPort 1.4
2.92 cm
17 cm
11.46 cm
Memory Size: 2GB
Memory Size: 2GB
Brand: Gigabyte
Price Range Ex VAT: 100 - 150
