Like nothing you’ve seen before
The AMD Radeon™ R9 Fury X graphics card is the world’s first total solution GPU with AMD-pioneered High-Bandwidth Memory (HBM) on-chip delivering extreme 4K performance and unbelievably "real" VR experiences.
Don’t just upgrade. Revolutionize with the AMD Radeon™ R9 Fury X graphics card.
AMD High Bandwidth Memory
- High-Bandwidth Memory with more than 3x the bandwidth per watt over GDDR5 along with a 4096-bit memory interface - the highest AMD GPU memory bandwidth ever.
- Sleek industrial styling including GPU Tach activity indicator and LED illumination all in a compact 7.5-inch card that’s all about raw graphics power.
- Powerful performance, bleeding-edge technology, liquid-cooled, whisper-quiet and future-ready for extreme 4K and VR gaming.
Redefine reality with AMD LiquidVR™ technology.
- Liquid-smooth images with high frame rates for a definitive VR experience.
- Get comfortable with low-latency head tracking.
- Designed for plug-and-play headset compatibility.
Enjoy the View in 4K.
- Command the competition at 4K resolution and beyond, fueled by a 4096-bit high-bandwidth memory interface for extreme performance and power efficiency.
- Take advantage of full support for DirectX® 12, Vulkan™, OpenGL® 4.5 and Mantle.
- Experience the smoothest gameplay without frame-tearing or stuttering with an AMD Eyefinity 3x1, using 1440p FreeSync™-enabled monitors for a massive 6K gameplay "surround view" panorama.
OC Guru II
Advanced intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance and OSD setting can be monitored and tuned in according to your own preference. -
HBM technology
Enjoy high speed bandwidth that will boost your gaming performance achieving high-framerates and smooth gameplay. -
AMD Eyefinity
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers advanced graphics display capabilities enabling massive desktop workspaces and immersive visual environments for the ultimate panoramic computing experience.
- Gigabyte GV-R9FURYX-4GD-B - graphics card - Radeon R9 Fury X - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon R9 Fury X
- Memory
- 4 GB HBM
- Core Clock
- 1050 MHz
- Effective Memory Clock
- 1000 MHz
- Memory Interface
- 4096-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- HDMI , 3 x DisplayPort
- API Supported
- OpenGL 4.4, DirectX 12
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1050 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Liquid cooling system, AMD Eyefinity Technology, OC Guru II
- Size
- 4 GB
- Technology
- HBM
- Effective Clock Speed
- 1000 MHz
- Bus Width
- 4096-bit
- Required Power Supply
- 750 W
- Additional Requirements
- Two 8-pin power connectors
- Software Included
- OC Guru ll
