GV-R939G1 GAMING-8GD - Gigabyte AMD Radeon R9 390
OC up to 1025MHz core clock by GPU Gauntlet sorting technology
WINDFORCE 2X with dual 90mm unique blade fan
8192MB high capacity memory fulfill the multi-screen and high definition gaming
0dB Semi-Passive Fan with LED indicators.
Stylish Metal Back-Plate
6-Phase GPU power design
Ultra Durable graphics card components
GIGABYTE OC GURU II Supported
GPU Radeon R9 390
Core Clock 1025 MHz
Memory Clock 6000 MHz
Memory Size 8192MB GDDR5
Bus Type PCI Express 3.0
Memory Bus 512-bit
Stream Processors 2816
Memory type 64Mx32
DirectX 11 Yes
DVI Port - DVI-D
DisplayPort x 3
HDMI x 1
3D' 11 - P: 14922 / X: 4661
3D' FS - Default: 10170 / Extreme: 5002
GPU Gauntlet Sorting
With GPU Gauntletâ„¢ Sorting, the Gigabyte SOC graphics card guarantees the higher overclocking capability in terms of excellent power switching
WINDFORCE 2X
Dual 90mm Unique blade fan design
The air flow is split through the triangle design at the fan edge, and is guided smoothly through the fan by the special 3D stripe curve design, effectively enhancing the air flow by 23% over traditional fans, whilst reducing air turbulence.
Fan Stop with Intuitive Fan Indicators
Equipped with the latest 0dB Semi-passive fan technology, the fans stop spinning when the GPU is under a set temperature for complete silence.
Featuring LED indicators on the top of the graphics card to provide an instant display of whether the fans are spinning or not.
Stylish Metal Back Plate
Glorious black metal back plate engraved with G1 GAMING logo inspires passion for gaming.
The airflow is spit through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence. -
Intuitive fan indicators
Featuring LED indicators on the top of the graphics card to provide an instant display of whether the fans are spinning or not. -
Heat pipe direct touch
Equipped with pure copper heat pipe direct touch technology, delivering superior cooling capacity and heat transfer efficiency at an extremely low noise level. -
Stylish metal back plate
- Gigabyte GV-R939G1 GAMING-8GD - OC Edition - graphics card - Radeon R9 390 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon R9 390
- Memory
- 8 GB GDDR5
- Core Clock
- 1025 MHz
- Effective Memory Clock
- 6 GHz
- Memory Interface
- 512-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , HDMI , 3 x DisplayPort
- API Supported
- OpenGL 4.4, DirectX 12
- 4.2 cm x 23.4 cm x 12.9 cm
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon R9 390
- Core Clock
- 1025 MHz
- Process Technology
- 28 nm
- Max Resolution
- 4096 x 2160
- 4
- API Supported
- Ultra Durable VGA, LED indicator, GIGABYTE GPU Gauntlet Sorting, GIGABYTE Super Overclock, GIGABYTE WindForce 2x, OC Guru II, 0dB semi-passive fans, Heat Pipe Direct Touch technology
- Size
- 8 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6 GHz
- Bus Width
- 512-bit
- Required Power Supply
- 600 W
- Additional Requirements
- 6-pin + 8-pin power connectors
- Software Included
- OC Guru ll
- 4.2 cm
- 23.4 cm
- 12.9 cm
