As opposed to the stereotype, Gigabyte is able to maximize fan size to 10 cm with the latest cooling design. With a 10 cm fan, the card is virtually silent that its noise level runs much lower.
- Powered by AMD Radeon R7 250 GPU
- Integrated with the first 2048MB DDR3 memory and 128-bit memory interface
- OC Edition - Core Clock: 1100 MHz (Std 1050 MHz)
- Features Single-Link DVI-D / HDMI / D-Sub
- Support PCI Express 3.0 x8 bus interface
- System power supply requirement: 400W
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK,FAN, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Gigabyte custom-designed 10 cm cooler
As opposed to the stereotype, Gigabyte is able to maximize fan size to 10 cm with the latest cooling design. With a 10 cm fan, the card is virtually silent that its noise level runs much lower. -
Gold plated HDMI
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. -
OC GURU ll
Instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
- Gigabyte GV-R725OC-2GI (rev. 2.0) - graphics card - Radeon R7 250 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x8
- Graphics Engine
- AMD Radeon R7 250
- Memory
- 2 GB DDR3
- Core Clock
- 1050 MHz
- Boost Clock
- 1100 MHz
- Effective Memory Clock
- 1.8 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 2
- Interfaces Details
- DVI-D (Single-Link) , HDMI , VGA
- API Supported
- OpenGL 4.2, DirectX 11.1
- 3.5 cm x 19.5 cm x 13 cm
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon R7 250
- Core Clock
- 1050 MHz
- Boost Clock
- 1100 MHz
- Process Technology
- 28 nm
- Max Resolution
- 2560 x 1600
- 2
- API Supported
- Ultra Durable 2, AMD HD3D Technology, AMD App Acceleration, GIGABYTE custom-designed 100 mm cooler, Graphics Core Next (GCN), Gold plated HDMI, OC Guru II
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.8 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 400 W
- Software Included
- AMD Catalyst Control Center, OC Guru ll
- 3.5 cm
- 19.5 cm
- 13 cm
