Product
Brand
Generic QuickDisk CD/DVD Duplicator - 1-10
Quicklinx: 75P2WS00 Mfr#: QD-DVD-1210
Looking for an affordable option to bring disc burning in house? The Microboards QD series 10 recorder DVD/CD duplicator is configured for your throughput requirements. The QD-DVD-1210 DVD Duplicator is perfectly suited to organizations that need to deliver small runs on demand or need to have in house control of their content. Ease of use and a compact footprint make the QD-DVD-1210 DVD duplicator suited for the front office or practically anywhere in the studio. One button copying gives the user the ability to make ten copies at a time at the highest recording speed available. Use it standalone (without connecting to a PC) or connect it to your PC for easy mastering over the USB port with the included recording software! The QD-DVD-1210 supports DVD+R and DVD-R, and can copy DVD Video or data. In addition, the QD-DVD-1210 supports all of the most popular CD recording formats, including audio, data, and more. Even dual-layer DVD discs can be copied on this versatile DVD duplicator.
Scream through your production with blistering fast 48x CD-R/20x DVD-R/+R recorders and an easy-to-use four-button interface. The QD towers make disc duplication an easy task, even if you're not a "computer wizard".
MicroBoards Quick Disc QD-DVD-1210 - DVD duplicator - USB 2.0 - external
DVD duplicator - external
USB 2.0
Optical Storage
10 x DVD-Writer
Write Speed
48x (CD) / 24x (DVD)
1 year warranty
USB 2.0
Built-in Devices
Status LCD
Optical Storage
10 x DVD-Writer
Write Speed
Supported Media Formats
CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Mixed-mode CD, Photo CD, Video CD, CD-ROM, CD+G (Karaoke CD), Super Video CD
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD-R DL
Buffer Size
32 MB
CD-Bridge, Video CD
1 x USB 2.0
1 x USB cable
Limited warranty - 1 year
