The vívofit 3 tracks any and all of your movement, including inactivity. So while you might lose track of time and forget to move, vívofit 3 won't. A red move bar appears on the display and a gentle alert sounds after 1 hour of inactivity. The move bar builds every 15 minutes until you reset it by walking for a couple of minutes.
The vívofit 3 follows your progress 24/7 thanks to its long-lasting battery life. It automatically monitors your rest when you go to sleep. It's water resistant so you can wear it in the pool or the shower.
The vívofit 3 learns your current activity level, then assigns an attainable daily goal. As you meet your milestones, vívofit 3 will adjust your goal for the next day, gradually nudging you toward a healthier lifestyle.
- Garmin vívofit 3 Style Collection Gabrielle activity tracker with band
- Product Type
- Activity tracker
- Tracking Data
- Distance, time, calories burned, heart rate (with optional heart rate sensor), activity, sleep activity, steps taken
- Connectivity
- ANT+/ANT
- Display
- Two-colour (monochrome) LCD 64 x 64 pixels - always-on display
- Band
- Band - size: L - changeable
- Idle alert, automatic exercise recognition
- Battery
- CR1632
- Battery Run Time
- Up to 12 month(s)
- 22.3 mm x 10.33 mm
- Product Type
- Activity tracker
- Tracking Data
- Wearing Style
- Wrist
- Clock Display
- Set Goals
- Sensors
- Accelerometer
Display
- LCD - two-colour (monochrome)
- Resolution
- 64 x 64 pixels
- Dimensions (WxH)
- 10 mm x 10 mm
- Always On Display (AOD)
- Wireless Interface
- ANT+/ANT
- Form Factor
- CR1632
- Run Time (Up To)
- 12 month(s)
Band
- Name
- Band
- Changeable
- Size
- L
- 22.3 mm
- 10.33 mm
- Preloaded Software
- Alarm Clock
- Protection
- Waterproof
- Included Accessories
- Black wrist strap, white wrist strap
- Max Depth of Water Resistance
- 50 m
