Product
Garmin Vivofit 3 WW Sculpted Fitness Activity Tracker Bangle
Quicklinx: DCC8WS00 Mfr#: 010-01608-30
Device Type: Wearable Tech
Type: Tracker
£83.33 ex VAT
£99.99 inc VAT
The vívofit 3 tracks any and all of your movement, including inactivity. So while you might lose track of time and forget to move, vívofit 3 won't. A red move bar appears on the display and a gentle alert sounds after 1 hour of inactivity. The move bar builds every 15 minutes until you reset it by walking for a couple of minutes.
The vívofit 3 follows your progress 24/7 thanks to its long-lasting battery life. It automatically monitors your rest when you go to sleep. It's water resistant so you can wear it in the pool or the shower.
The vívofit 3 learns your current activity level, then assigns an attainable daily goal. As you meet your milestones, vívofit 3 will adjust your goal for the next day, gradually nudging you toward a healthier lifestyle.
Garmin vívofit 3 Style Collection Gabrielle activity tracker with band
Activity tracker
ANT+/ANT
Display
Two-colour (monochrome) LCD 64 x 64 pixels
Tracking Data
Distance, time, calories burned, heart rate (with optional heart rate sensor), activity, sleep activity, steps taken
Band
Band - (L)
Always-on display, idle alert, changeable band, automatic exercise recognition
Battery Run Time
Up to 12 month(s)
22.3 mm x 10.33 mm
Activity tracker
Tracking Data
Wearing Style
Wrist
Clock Display
Set Goals
Always-on display, idle alert, changeable band, automatic exercise recognition, accelerometer
Display
LCD - two-colour (monochrome)
Resolution
64 x 64 pixels
Dimensions (WxH)
10 mm x 10 mm
Wireless Interface
ANT+/ANT
CR1632
Run Time (Up To)
12 month(s)
Band
Name
Band
Size
L
22.3 mm
10.33 mm
Preloaded Software
Alarm Clock
Protection
Waterproof
Black wrist strap, white wrist strap
Max Depth of Water Resistance
50 m
Type: Tracker
Brand: Garmin
Price Range Ex VAT: 50 - 100
